[QGIS-Developer] PyQGIS problem with QWebEngineView / QtDesigner Crash with QWebEngineView
Roberto Benet rbenet71 at gmail.com
Sat Feb 6 00:28:21 PST 2021
I have QGIS 3.16.3-Hannover installed with Qt 5.11.2 and 64-bit Windows 10.
In two more computers I also have it installed in similar conditions.
I am using the PyQGIS to stand-alone applications from QGIS and I think
there is something that is not working well within PyQGIS because I cannot
use the QWebEngineView and the QWebKit yes.
The symptoms I have are:
1.- If in the QtDesigner that is installed with QGIS, I add the
QWebEngineView widget in the design, the program directly crash and stops
running.
2.- If in a stand-alone application I start a QWebEngineView it gives me an
error:
Code:
    from qgis.PyQt.QtWidgets import QWidget, QApplication, QMainWindow,
QFileDialog
    from PyQt5.QtWebEngineWidgets import QWebEngineView
    import sys
    class temp (QWebEngineView):
        def __init __ (self):
            super () .__ init __ ()
    if __name__ == '__main__':
        # We create the instance of the created class and show the window on
the screen
        app = QApplication (sys.argv)
        win = temp ()
        win.show ()
        sys.exit (app.exec_ ())
and the error it gives is:
Qt WebEngine ICU data not found at C: /OSGeo4W64/apps/Qt5/resources.Trying
parent directory ...
Qt WebEngine ICU data not found at C: / OSGeo4W64 / apps / Qt5. Trying
application directory ...
Qt WebEngine ICU data not found at C: / OSGeo4W64 / apps / Python37. Trying
fallback directory ... The application MAY NOT work. Installed
Qt WebEngine locales directory not found at location C: / OSGeo4W64 / apps /
Qt5 / translationss \ qtwebengine_locales. Trying application directory ...
Python37 \ qtwebengine_locales. Trying fallback directory ... Translations
MAY NOT not be correct.
[0205 / 214808.373: ERROR: icu_util.cc (179)] Invalid file descriptor to
ICU data received. [0205 / 214808.491: FATAL: icu_util.cc (311)] Check
failed: result. Backtrace:
I have looked at this link:
https://issues.qgis.org/issues/18155
3 years ago it seems that this error could not be solved ...
Then with this other:
https://forum.qt.io/topic/70457/qt-5-7-qtwebenginewidgets-not-working-on-lin
ux/3
It seems that the following folders are missing, among others, that I do not
have in my installation: resources, qtwebengine_locales, ...
I have uninstalled the qwebengine with the OsGeo4W setup. And then I have
reinstalled it.
I have seen that QGis uses version 5.10.1, I have tried to install it
through pip install, but it tells me that there is only the version from
5.12.
I think it must be that the QWebEngineView is not installed correctly with
QGIS. Because if that works if I use it with the installation of python38 or
python39.
Este correo electrónico ha sido comprobado en busca de virus por AVG.
http://www.avg.com
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210206/a34a0cd6/attachment-0001.html>
More information about the QGIS-Developer mailing list
