[QGIS-Developer] Building QGIS with Visual Studio 2019 CE and vcpkg
Mats Taraldsvik
mats.taraldsvik at gmail.com
Thu Feb 11 02:29:59 PST 2021
Hi Stefan,
Thank you for this excellent guide to compile with vcpkg, it worked right
away after me struggling with the official guide+CMake compilation for a
couple of hours.
I did make a few modifications that might help:
1. Release build:
- geos_c.lib was detected automatically, and for some reason I did not need
to explicitly set GEOS_LIBRARY
2. Debug build:
I noticed: 1> [CMake] -- Found ZSTD:
C:/Users/mattar/Source/Repos/vcpkg_qgis/installed/x64-windows/lib/zstd.lib
in the logs and you wrote:
> The build will fail because the execution of crssync.exe fails. That's
because crssync.exe tries to load zstd.dll instead of zstdd.dll. I haven't
figured out why, yet. An easy workaround is copying zstdd.dll to zstd.dll
in QGIS\out\build\x64-Debug\output\bin. Then restart the build and it
should succeed.
By setting ZSTD_LIBRARY explicitly to
<your-vcpkg-root>/installed/x64-windows/debug/lib/zstdd.lib it picked the
right lib and dll:
Then log changed to: 1> [CMake] -- Found ZSTD:
C:/Users/mattar/Source/Repos/vcpkg_qgis/installed/x64-windows/debug/lib/zstdd.lib
I hope this does help a bit.
I'm an outsider to this community, but my humble suggestion _when this work
is complete_ (what's missing except for python support?):
- add your CMakeSettings.json to the build description or to
src/CMakeSettings.json
- vcpkg has a new feature "manifests", where a file vcpkg.json describes
all dependencies. this should also be added or described (instead of the
vcpkg install command).
- vcpkg just got versioning, which might help align the requirements with
the rest of qgis
- I see that vcpkg already has flex and bison
(<your-vcpkg-root>/downloads/tools/winflexbison), so if there is a way for
win_bison.exe and win_flex.exe to be copied to the build directory, these
could be used instead of cygwin, making the build even easier)
- vcpkg does have binary caching, perhaps making a github actions CI build
using this method feasible?
Anyway, thank you for your efforts! It made the first QGIS-step more
pleasant. :)
Best regards,
Mats Taraldsvik
On Mon, Feb 1, 2021 at 4:24 PM Uhrig, Stefan <stefan.uhrig at sap.com> wrote:
> Hi all,
> In my opinion, the build with Visual Studio 2019 and vcpkg is still too
> experimental to add it to the INSTALL.md file. It might break any day if
> QGIS requires a package or package version that is not available from vcpkg.
> Actually, I like the idea to add it to the “Show & tell” category. We can
> ask the community for their experiences with that setup. Does it work, is
> it getting used? If it is used by some “critical mass” and works over a
> longer time without issues, we can add instructions to the INSTALL.md file.
> Maybe we can add a hint to the INSTALL.md file that the not so
> faint-hearted developers might give it a try and provide a link to the
> “Show & tell” post.
> However, to be really useful, the debug build should also work with Python
> bindings and QGIS processing. I got it working for release builds (just
> needed to install the required Python dependencies via pip install
> <package>), but that does not work for debug builds. Someone solved that
> some years ago in another context (
> https://www.riverbankcomputing.com/pipermail/pyqt/2012-April/031385.html),
> so I might get it working. I’ll give it a try.
> Furthermore, I’d like to investigate the zstd.dll vs zstdd.dll load issue
> before publishing the build instructions.
> Best regards,
> Stefan
> *From:* QGIS-Developer <qgis-developer-bounces at lists.osgeo.org> *On
> Behalf Of *DelazJ
> *Sent:* Monday, February 1, 2021 10:49 AM
> *To:* Jorge Gustavo Rocha <jgr at di.uminho.pt>
> *Cc:* qgis-developer <qgis-developer at lists.osgeo.org>
> *Subject:* Re: [QGIS-Developer] Building QGIS with Visual Studio 2019 CE
> and vcpkg
> Hi,
> Why not in the build instructions of the code repo instead:
> https://github.com/qgis/QGIS/blob/master/INSTALL.md? If it's a working
> process, easy to replicate, this is the place I'd expect this kind of
> information.
> Regards,
> Harrissou
> Le dim. 31 janv. 2021 à 15:55, Jorge Gustavo Rocha <jgr at di.uminho.pt> a
> écrit :
> Hi Stefan,
> We have now a new tab on github called 'discussions'[1]. Your detailed
> instructions are a good candidate to write down a new entry there, under
> 'Show and tell' category. The goal is to keep this information next to
> the repo. You can use the markdown syntax to enhance the writing format.
> You can also add some print screens.
> This is just a suggestion. Feel free to put it there or not.
> Regards (and thank you!),
> Jorge Gustavo
> [1] https://github.com/qgis/QGIS/discussions
> Às 14:13 de 31/01/21, Uhrig, Stefan escreveu:
> > Install Visual Studio Community 2019: Select "Desktop development with
> > C++" under "Workloads" and "C++ MFC for latest v142 build tools (x86 &
> > x64)" under "Individual components". Verify that you install "Windows 10
> > SDK (10.0.18362.0)" or higher.
> > Install Git for Windows and Python 3.
> > Download
> https://sourceforge.net/projects/winflexbison/files/win_flex_bison3-latest.zip/download
> > and extract it to a location of your choice (avoid space characters in
> > the target path).
> > Follow the vcpkg "Quick Start: Windows" instructions at
> > https://github.com/microsoft/vcpkg#quick-start-windows. Make sure to
> > execute the "vcpkg integrate install" command.
> > Install the required dependencies via:
> > vcpkg --triplet=x64-windows install exiv2 gdal gsl libspatialindex
> > libspatialite libzip opencl protobuf qca qscintilla qt5 qt5-serialport
> > qt5-location qt5-winextras qtkeychain qwt zstd
> > This may take a while as this creates a Debug and a Release build of
> > each dependency from source.
> > Clone the QGIS repostiory. The path to the QGIS repository should not
> > contain any space characters.
> > Start Visual Studio and open the QGIS CMakeLists.txt file via "File -->
> > Open --> CMake...". This will start the CMake generation, which will
> > fail. You will need several configuration rounds until everything is
> > setup properly.
> > Let's start with a Release build because that requires less tweaking. Go
> > to "Project --> CMake Settings". Delete the default configuration
> > ("x64-Debug (default)").
> > Add a new "x64-Release" configuration and set "Configuration type" to
> > "Release". Save the CMakeSettings.json file, which will start a new
> > CMake generation. "FIND_FLEX" will fail, so you need to set the
> > "FLEX_EXECUTABLE" path manually in section "CMake variables and cache".
> > Browse to your win_flex.exe file. Additionally, disable "WITH_BINDINGS"
> > and "WITH_QGIS_PROCESS". Save the file. Next set "BISON_EXECUTABLE" to
> > your win_bison.exe file and save again. Disable "WITH_QTWEBKIT" and
> > save. Set "QCA_LIBRARY" to
> > "<vcpkg-root>\installed\x64-windows\lib\qca.lib" and save. Configuration
> > should now succeed, but you have to change "GEOS_LIBRARY" from
> > "geos.lib" to "geos_c.lib". Save and start the build after CMake
> > generation has finished.
> > Select "qgis.exe (output\bin\qgis.exe)" as start-up item in the toolbar
> > and start QGIS.
> > Now let's do the same for a Debug build. Add a "x64-Debug" configuration
> > and save. Change to the "x64-Debug" configuration in the toolbar. Repeat
> > the steps from above (set flex and bison paths etc.). When selecting
> > libraries, take the libraries from
> > "<vcpkg-root>\installed\x64-windows\debug\lib". Most libraries will have
> > a "d" or "_d" as name suffix. The CMake generation will not always
> > select the debug versions of libraries. Hence, go over the CMake
> > variables and change release library paths to debug library paths, e.g.
> > "<vcpkg-root>\installed\x64-windows\debug\lib\geos_cd.lib" for
> > GEOS_LIBRARY. I'll append my CMakeSettings.json file as reference to
> > this mail. Save again and start the build.
> > haven't figured out why, yet. An easy workaround is copying zstdd.dll to
> > zstd.dll in QGIS\out\build\x64-Debug\output\bin. Then restart the build
> > and it should succeed.
> > You should then be able to start and debug qgis.exe and its
> > dependencies. Note that some vcpkg portfiles forget to copy over the
> > .pdb files. For example, proj is affected. If you find such a library
> > with a missing .pdb file, check whether the portfile (e.g.
> > "<vcpkg-root>\ports\proj4\portfile.cmake") contains the
> > "vcpkg_copy_pdbs()" call. If not, just add it at the end, re-install the
> > dependency and copy over the .pdb file to the QGIS output directory.
> > I'm currently trying to get QGIS working with Python bindings. I got the
> > build working, however I'm struggling with the debug build execution.
> > The debug Python library seems to be unable to load the Release build Qt
> > libraries that come with PyQt5. Well, I'll keep trying and if I succeed,
> > I'll update the instructions.
> > Here is my CMakeSettings.json file for reference:
> > "configurations": [
> > "name": "x64-Release",
> > "generator": "Ninja",
> > "configurationType": "Release",
> > "buildRoot": "${projectDir}\\out\\build\\${name}",
> > "installRoot": "${projectDir}\\out\\install\\${name}",
> > "cmakeCommandArgs": "",
> > "buildCommandArgs": "",
> > "ctestCommandArgs": "",
> > "inheritEnvironments": [ "msvc_x64_x64" ],
> > "variables": [
> > "name": "WITH_BINDINGS",
> > "value": "False",
> > "type": "BOOL"
> > "name": "WITH_QGIS_PROCESS",
> > "value": "False",
> > "type": "BOOL"
> > "name": "FLEX_EXECUTABLE",
> > "value": "C:/src/tools/win_flex.exe",
> > "type": "FILEPATH"
> > "name": "BISON_EXECUTABLE",
> > "value": "C:/src/tools/win_bison.exe",
> > "type": "FILEPATH"
> > "name": "WITH_QTWEBKIT",
> > "value": "False",
> > "type": "BOOL"
> > "name": "QCA_LIBRARY",
> > "value": "C:/src/vcpkg/installed/x64-windows/lib/qca.lib",
> > "type": "FILEPATH"
> > "name": "GEOS_LIBRARY",
> > "value": "C:/src/vcpkg/installed/x64-windows/lib/geos_c.lib",
> > "type": "FILEPATH"
> > "name": "x64-Debug",
> > "configurationType": "Debug",
> > "variables": [
> > "type": "FILEPATH"
> > "type": "FILEPATH"
> > "value": "False",
> > "type": "BOOL"
> > "value": "False",
> > "type": "BOOL"
> > "value": "False",
> > "type": "BOOL"
> > "value":
> "C:/src/vcpkg/installed/x64-windows/debug/lib/qcad.lib",
> > "type": "FILEPATH"
> > "value":
> > "C:/src/vcpkg/installed/x64-windows/debug/lib/geos_cd.lib",
> > "type": "FILEPATH"
> > "name": "GSL_LIB",
> > "value":
> "C:/src/vcpkg/installed/x64-windows/debug/lib/gsld.lib",
> > "type": "FILEPATH"
> > "name": "GSLCBLAS_LIB",
> > "value":
> > "C:/src/vcpkg/installed/x64-windows/debug/lib/gslcblasd.lib",
> > "type": "FILEPATH"
> > "name": "PROJ_LIBRARY",
> > "value":
> > "C:/src/vcpkg/installed/x64-windows/debug/lib/proj_d.lib",
> > "type": "FILEPATH"
> > "name": "QSCINTILLA_LIBRARY",
> > "value":
> > "C:/src/vcpkg/installed/x64-windows/debug/lib/qscintilla2_qt5d.lib",
> > "type": "FILEPATH"
> > "name": "QTKEYCHAIN_LIBRARY",
> > "value":
> > "C:/src/vcpkg/installed/x64-windows/debug/lib/qt5keychaind.lib",
> > "type": "FILEPATH"
> > "name": "QWT_LIBRARY",
> > "value":
> "C:/src/vcpkg/installed/x64-windows/debug/lib/qwtd.lib",
> > "type": "FILEPATH"
> > "name": "SPATIALINDEX_LIBRARY",
> > "value":
> > "C:/src/vcpkg/installed/x64-windows/debug/lib/spatialindex-64d.lib",
> > "type": "FILEPATH"
> > *From:*i-s-o <46.i.s.o.64 at gmail.com>
> > *Sent:* Saturday, January 30, 2021 5:58 PM
> > *To:* Uhrig, Stefan <stefan.uhrig at sap.com>
> > *Cc:* qgis-developer <QGIS-Developer at lists.osgeo.org>
> > and vcpkg
> > I am very interested in trying out your solution. Could you share the
> > required steps?
> > Thx.
> > On Fri, Jan 29, 2021, 09:25 Uhrig, Stefan <stefan.uhrig at sap.com
> > <mailto:stefan.uhrig at sap.com>> wrote:
> > TL;DR: It is currently possible to build the QGIS core app with
> > Visual Studio 2019 and vcpkg, which makes debugging QGIS
> > dependencies easy.
> > Hi all,
> > Some time ago I discovered vcpkg
> > (https://github.com/microsoft/vcpkg). vcpkg is a package manager
> > that downloads package source code to your local machine and builds
> > the package locally. Recently, I discovered that vcpkg should be
> > able to provide all dependencies to build at least the QGIS core
> > application. Hence, I gave it a try.
> > Basically, it worked out of the box. I started with a fresh Windows
> > 10 installation, installed Visual Studio 2019 Community Edition,
> > Git, vcpkg, Python 3 and flex and bison for Windows. I fetched all
> > other dependencies via vcpkg. It was not necessary to even touch a
> > single file in the repository. I could just open the main
> > CMakeLists.txt file in Visual Studio and only had to tweak the CMake
> > cache (the CMake find macros that come with QGIS are not aware of
> > vcpkg, so I had to set some paths manually). I had to switch off
> > some extensions though as the required dependencies were not
> > available via vcpkg (WITH_BINDINGS, WITH_QGIS_PROCESS,
> > WITH_QTWEBKIT). The build did not report any errors, I could start
> > the application and it seems to work, but I did some light testing
> only.
> > I mainly tried it because I enjoy debugging with Visual Studio more
> > than with gdb (or gdb wrapped in some IDE). In my experience, the
> > performance of the Visual Studio debugger is better and it is more
> > stable, especially in long debug sessions.
> > I don’t want to promote official building support of QGIS with
> > vcpkg. Providing the dependencies via OSGeo4W is much more reliable.
> > However, if you don’t mind the experimental nature of this setup and
> > you want to be able to debug into QGIS’ dependencies, you might give
> > it a try. Especially, if you want to track the cause of a crash in
> > one of QGIS’ dependencies, this setup might be helpful. You have the
> > source code and debug versions of the dependencies, so the debugger
> > will jump to the crashing code line and you can inspect all the
> > variables of the dependency.
> > If someone is interested in trying it, give me a note. I can then
> > assemble detailed instructions on how to make it work. It took me a
> > while to figure out which packages are needed and how the CMake
> > cache needs to be tweaked.
> > Best regards,
> > Stefan
> > QGIS-Developer mailing list
> > QGIS-Developer at lists.osgeo.org <mailto:
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> J. Gustavo
> Jorge Gustavo Rocha
> Departamento de Informática
> Universidade do Minho
> 4710-057 Braga
> Gabinete 3.29 (Piso 3)
> Tel: +351 253604480
> Fax: +351 253604471
> Móvel: +351 910333888
> skype: nabocudnosor
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210211/7be6e20c/attachment-0001.html>
