[QGIS-Developer] Add a WFS/WMS (or possibly any data source) from API
Etienne Trimaille etienne.trimaille at gmail.com
Tue Feb 16 00:41:24 PST 2021
You can have a look to the "Menu from project" plugin. Especially if you
use the project stored in database, it can be easy to maintain for you to
edit layers available in the menu.
If you really want to add entries in WMS WFS, you can use a custom QGIS INI
file within your organisation or add them with QgsSettings
Pada tanggal Sel, 16 Feb 2021 15:13, Janvier Thomas <t.janvier at brgm.fr>
menulis:
> Hi all,
> I’m looking for an automated/scriptable method to publish (and update) an
> organization-wide set of webservices.
> The idea is to deploy  a “collection of data resources” as a collection of
> WMS/WFS, among an organization…
> It’s intended to be maintainable (update/add/remove links on-the-fly) so
> all coworkers will have access to the same datafeeds without having to
> manually add each URL (especially for non-expert users).
> My first thought was to provide a plugin that only job would be to
> register “connections” at launch and update the version of such plugin
> along with the connections list then deploy the update through an internal
> QGIS repo…
> But I did not find how to “register” the webservices through the API (I
> found tons of doc about how to request them to serve layers, nothing on the
> “add connection to sources”)…
> Thanks in advance !
> *Thomas JANVIER*
> 3D Geomodelling developper
> DGR/CIM
> 3 av. Claude-Guillemin - BP 36009 - 45060 ORLÉANS Cedex 2
> Tel.: +33 (0)2 38 64 33 39/ t.janvier at brgm.fr <courriel at brgm.fr>
> *www.brgm.fr* <http://www.brgm.fr/>
> *BRGM – THE FRENCH GEOLOGICAL SURVEY*
> Newsletter BRGM Infos
> <http://www.brgm.fr/content/newsletters?pk_campaign=signature-brgm&pk_kwd=newsletter>
> [image: cid:image002.jpg at 01D6BE76.48D64A70] <https://twitter.com/BRGM_fr>
> [image: cid:image003.jpg at 01D6BE76.48D64A70]
> <https://www.linkedin.com/company/brgm>   [image:
> cid:image004.jpg at 01D6BE76.48D64A70] <https://www.instagram.com/brgm_fr/>
>    [image: cid:image005.jpg at 01D6BE76.48D64A70]
> <https://www.youtube.com/user/brgmtv>
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210216/e11cdff3/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210216/e11cdff3/attachment-0001.png>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210216/e11cdff3/attachment-0005.jpg>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210216/e11cdff3/attachment-0006.jpg>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210216/e11cdff3/attachment-0007.jpg>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210216/e11cdff3/attachment-0008.jpg>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210216/e11cdff3/attachment-0009.jpg>
More information about the QGIS-Developer mailing list
