[QGIS-Developer] Building QGIS with Visual Studio 2019 CE and vcpkg
Jorge Gustavo Rocha jgr at di.uminho.pt
Tue Feb 16 10:01:27 PST 2021
Hi Stefan,
Yes, GitHub discussions were removed. I don't know why.
Regards,
Jorge
Às 15:48 de 16/02/21, Uhrig, Stefan escreveu:
> Hi Mats,
> Thanks for the feedback! Good to hear that it worked for you. And thanks
> for sharing your configuration insights!
> When I last tried, geos_c.lib was detected as well. So, this seems to be
> fixed. Thanks for the ZSTD hint, I missed the “Show advanced variables”
> checkbox in Visual Studio.
> @Jorge: I planned to add the instructions to the discussion section
> first, but it seems to be gone. Was it removed?
> @All: Are there concerns adding these instructions to
> https://github.com/qgis/QGIS/blob/master/INSTALL.mdwith an
> “experimental” hint? If there aren’t any concerns, I can prepare a pull
> request.
> Best regards,
> Stefan
> *From:*Mats Taraldsvik <mats.taraldsvik at gmail.com>
> *Sent:* Thursday, February 11, 2021 11:30 AM
> *To:* Uhrig, Stefan <stefan.uhrig at sap.com>
> *Cc:* DelazJ <delazj at gmail.com>; Jorge Gustavo Rocha <jgr at di.uminho.pt>;
> qgis-developer <qgis-developer at lists.osgeo.org>
> *Subject:* Re: [QGIS-Developer] Building QGIS with Visual Studio 2019 CE
> and vcpkg
> Hi Stefan,
> Thank you for this excellent guide to compile with vcpkg, it worked
> right away after me struggling with the official guide+CMake compilation
> for a couple of hours.
> I did make a few modifications that might help:
> 1. Release build:
> - geos_c.lib was detected automatically, and for some reason I did not
> need to explicitly set GEOS_LIBRARY
> 2. Debug build:
> I noticed: 1> [CMake] -- Found ZSTD:
> C:/Users/mattar/Source/Repos/vcpkg_qgis/installed/x64-windows/lib/zstd.lib
> in the logs and you wrote:
>> The build will fail because the execution of crssync.exe fails. That's
> because crssync.exe tries to load zstd.dll instead of zstdd.dll. I
> haven't figured out why, yet. An easy workaround is copying zstdd.dll to
> zstd.dll in QGIS\out\build\x64-Debug\output\bin. Then restart the build
> and it should succeed.
> By setting ZSTD_LIBRARY explicitly to
> <your-vcpkg-root>/installed/x64-windows/debug/lib/zstdd.lib it picked
> the right lib and dll:
> Then log changed to: 1> [CMake] -- Found ZSTD:
> C:/Users/mattar/Source/Repos/vcpkg_qgis/installed/x64-windows/debug/lib/zstdd.lib
> I hope this does help a bit.
> I'm an outsider to this community, but my humble suggestion _when this
> work is complete_ (what's missing except for python support?):
> - add your CMakeSettings.json to the build description or to
> src/CMakeSettings.json
> - vcpkg has a new feature "manifests", where a file vcpkg.json describes
> all dependencies. this should also be added or described (instead of the
> vcpkg install command).
> - vcpkg just got versioning, which might help align the requirements
> with the rest of qgis
> - I see that vcpkg already has flex and bison
> (<your-vcpkg-root>/downloads/tools/winflexbison), so if there is a way
> for win_bison.exe and win_flex.exe to be copied to the build directory,
> these could be used instead of cygwin, making the build even easier)
> - vcpkg does have binary caching, perhaps making a github actions CI
> build using this method feasible?
> Anyway, thank you for your efforts! It made the first QGIS-step more
> pleasant. :)
> Best regards,
> Mats Taraldsvik
> On Mon, Feb 1, 2021 at 4:24 PM Uhrig, Stefan <stefan.uhrig at sap.com
> <mailto:stefan.uhrig at sap.com>> wrote:
>     Hi all,
>     In my opinion, the build with Visual Studio 2019 and vcpkg is still
>     too experimental to add it to the INSTALL.md file. It might break
>     any day if QGIS requires a package or package version that is not
>     available from vcpkg.
>     Actually, I like the idea to add it to the “Show & tell” category.
>     We can ask the community for their experiences with that setup. Does
>     it work, is it getting used? If it is used by some “critical mass”
>     and works over a longer time without issues, we can add instructions
>     to the INSTALL.md file. Maybe we can add a hint to the INSTALL.md
>     file that the not so faint-hearted developers might give it a try
>     and provide a link to the “Show & tell” post.
>     However, to be really useful, the debug build should also work with
>     Python bindings and QGIS processing. I got it working for release
>     builds (just needed to install the required Python dependencies via
>     pip install <package>), but that does not work for debug builds.
>     Someone solved that some years ago in another context
>     (https://www.riverbankcomputing.com/pipermail/pyqt/2012-April/031385.html),
>     so I might get it working. I’ll give it a try.
>     Furthermore, I’d like to investigate the zstd.dll vs zstdd.dll load
>     issue before publishing the build instructions.
>     Best regards,
>     Stefan
>     *From:*QGIS-Developer <qgis-developer-bounces at lists.osgeo.org
>     <mailto:qgis-developer-bounces at lists.osgeo.org>> *On Behalf Of *DelazJ
>     *Sent:* Monday, February 1, 2021 10:49 AM
>     *To:* Jorge Gustavo Rocha <jgr at di.uminho.pt <mailto:jgr at di.uminho.pt>>
>     *Cc:* qgis-developer <qgis-developer at lists.osgeo.org
>     <mailto:qgis-developer at lists.osgeo.org>>
>     2019 CE and vcpkg
>     Hi,
>     Why not in the build instructions of the code repo instead:
>     https://github.com/qgis/QGIS/blob/master/INSTALL.md? If it's a
>     working process, easy to replicate, this is the place I'd expect
>     this kind of information.
>     Regards,
>     Harrissou
>     Le dim. 31 janv. 2021 à 15:55, Jorge Gustavo Rocha <jgr at di.uminho.pt
>     <mailto:jgr at di.uminho.pt>> a écrit :
>         Hi Stefan,
>         We have now a new tab on github called 'discussions'[1]. Your
>         detailed
>         instructions are a good candidate to write down a new entry
>         there, under
>         'Show and tell' category. The goal is to keep this information
>         next to
>         the repo. You can use the markdown syntax to enhance the writing
>         format.
>         You can also add some print screens.
>         This is just a suggestion. Feel free to put it there or not.
>         Regards (and thank you!),
>         Jorge Gustavo
>         [1] https://github.com/qgis/QGIS/discussions
>         Às 14:13 de 31/01/21, Uhrig, Stefan escreveu:
>         > Install Visual Studio Community 2019: Select "Desktop
>         development with
>         > C++" under "Workloads" and "C++ MFC for latest v142 build
>         tools (x86 &
>         > x64)" under "Individual components". Verify that you install
>         "Windows 10
>         > SDK (10.0.18362.0)" or higher.
>         > Install Git for Windows and Python 3.
>         > Download
>         https://sourceforge.net/projects/winflexbison/files/win_flex_bison3-latest.zip/download
>         > and extract it to a location of your choice (avoid space
>         characters in
>         > the target path).
>         > Follow the vcpkg "Quick Start: Windows" instructions at
>         > https://github.com/microsoft/vcpkg#quick-start-windows. Make
>         sure to
>         > execute the "vcpkg integrate install" command.
>         > Install the required dependencies via:
>         > vcpkg --triplet=x64-windows install exiv2 gdal gsl libspatialindex
>         > libspatialite libzip opencl protobuf qca qscintilla qt5
>         qt5-serialport
>         > qt5-location qt5-winextras qtkeychain qwt zstd
>         > This may take a while as this creates a Debug and a Release
>         build of
>         > each dependency from source.
>         > Clone the QGIS repostiory. The path to the QGIS repository
>         should not
>         > contain any space characters.
>         > Start Visual Studio and open the QGIS CMakeLists.txt file via
>         "File -->
>         > Open --> CMake...". This will start the CMake generation,
>         which will
>         > fail. You will need several configuration rounds until
>         everything is
>         > setup properly.
>         > Let's start with a Release build because that requires less
>         tweaking. Go
>         > to "Project --> CMake Settings". Delete the default configuration
>         > ("x64-Debug (default)").
>         > Add a new "x64-Release" configuration and set "Configuration
>         type" to
>         > "Release". Save the CMakeSettings.json file, which will start
>         a new
>         > CMake generation. "FIND_FLEX" will fail, so you need to set the
>         > "FLEX_EXECUTABLE" path manually in section "CMake variables
>         and cache".
>         > Browse to your win_flex.exe file. Additionally, disable
>         "WITH_BINDINGS"
>         > and "WITH_QGIS_PROCESS". Save the file. Next set
>         "BISON_EXECUTABLE" to
>         > your win_bison.exe file and save again. Disable
>         "WITH_QTWEBKIT" and
>         > save. Set "QCA_LIBRARY" to
>         > "<vcpkg-root>\installed\x64-windows\lib\qca.lib" and save.
>         Configuration
>         > should now succeed, but you have to change "GEOS_LIBRARY" from
>         > "geos.lib" to "geos_c.lib". Save and start the build after CMake
>         > generation has finished.
>         > Select "qgis.exe (output\bin\qgis.exe)" as start-up item in
>         the toolbar
>         > and start QGIS.
>         > Now let's do the same for a Debug build. Add a "x64-Debug"
>         configuration
>         > and save. Change to the "x64-Debug" configuration in the
>         toolbar. Repeat
>         > the steps from above (set flex and bison paths etc.). When
>         selecting
>         > libraries, take the libraries from
>         > "<vcpkg-root>\installed\x64-windows\debug\lib". Most libraries
>         will have
>         > a "d" or "_d" as name suffix. The CMake generation will not always
>         > select the debug versions of libraries. Hence, go over the CMake
>         > variables and change release library paths to debug library
>         paths, e.g.
>         > "<vcpkg-root>\installed\x64-windows\debug\lib\geos_cd.lib" for
>         > GEOS_LIBRARY. I'll append my CMakeSettings.json file as
>         reference to
>         > this mail. Save again and start the build.
>         fails. That's
>         zstdd.dll to
>         the build
>         > You should then be able to start and debug qgis.exe and its
>         > dependencies. Note that some vcpkg portfiles forget to copy
>         over the
>         > .pdb files. For example, proj is affected. If you find such a
>         library
>         > with a missing .pdb file, check whether the portfile (e.g.
>         > "<vcpkg-root>\ports\proj4\portfile.cmake") contains the
>         > "vcpkg_copy_pdbs()" call. If not, just add it at the end,
>         re-install the
>         > dependency and copy over the .pdb file to the QGIS output
>         directory.
>         > I'm currently trying to get QGIS working with Python bindings.
>         I got the
>         > build working, however I'm struggling with the debug build
>         execution.
>         > The debug Python library seems to be unable to load the
>         Release build Qt
>         > libraries that come with PyQt5. Well, I'll keep trying and if
>         I succeed,
>         > I'll update the instructions.
>         > Here is my CMakeSettings.json file for reference:
>         >   "configurations": [
>         >       "name": "x64-Release",
>         >       "generator": "Ninja",
>         >       "configurationType": "Release",
>         >       "buildRoot": "${projectDir}\\out\\build\\${name}",
>         >       "installRoot": "${projectDir}\\out\\install\\${name}",
>         >       "cmakeCommandArgs": "",
>         >       "buildCommandArgs": "",
>         >       "ctestCommandArgs": "",
>         >       "inheritEnvironments": [ "msvc_x64_x64" ],
>         >       "variables": [
>         >           "name": "WITH_BINDINGS",
>         >           "value": "False",
>         >           "type": "BOOL"
>         >           "name": "WITH_QGIS_PROCESS",
>         >           "value": "False",
>         >           "type": "BOOL"
>         >           "name": "FLEX_EXECUTABLE",
>         >           "value": "C:/src/tools/win_flex.exe",
>         >           "type": "FILEPATH"
>         >           "name": "BISON_EXECUTABLE",
>         >           "value": "C:/src/tools/win_bison.exe",
>         >           "type": "FILEPATH"
>         >           "name": "WITH_QTWEBKIT",
>         >           "value": "False",
>         >           "type": "BOOL"
>         >           "name": "QCA_LIBRARY",
>         >           "value":
>         "C:/src/vcpkg/installed/x64-windows/lib/qca.lib",
>         >           "type": "FILEPATH"
>         >           "name": "GEOS_LIBRARY",
>         >           "value":
>         "C:/src/vcpkg/installed/x64-windows/lib/geos_c.lib",
>         >           "type": "FILEPATH"
>         >       "name": "x64-Debug",
>         >       "configurationType": "Debug",
>         >       "variables": [
>         >           "type": "FILEPATH"
>         >           "type": "FILEPATH"
>         >           "value": "False",
>         >           "type": "BOOL"
>         >           "value": "False",
>         >           "type": "BOOL"
>         >           "value": "False",
>         >           "type": "BOOL"
>         >           "value":
>         "C:/src/vcpkg/installed/x64-windows/debug/lib/qcad.lib",
>         >           "type": "FILEPATH"
>         >           "value":
>         > "C:/src/vcpkg/installed/x64-windows/debug/lib/geos_cd.lib",
>         >           "type": "FILEPATH"
>         >           "name": "GSL_LIB",
>         >           "value":
>         "C:/src/vcpkg/installed/x64-windows/debug/lib/gsld.lib",
>         >           "type": "FILEPATH"
>         >           "name": "GSLCBLAS_LIB",
>         >           "value":
>         > "C:/src/vcpkg/installed/x64-windows/debug/lib/gslcblasd.lib",
>         >           "type": "FILEPATH"
>         >           "name": "PROJ_LIBRARY",
>         >           "value":
>         > "C:/src/vcpkg/installed/x64-windows/debug/lib/proj_d.lib",
>         >           "type": "FILEPATH"
>         >           "name": "QSCINTILLA_LIBRARY",
>         >           "value":
>         "C:/src/vcpkg/installed/x64-windows/debug/lib/qscintilla2_qt5d.lib",
>         >           "type": "FILEPATH"
>         >           "name": "QTKEYCHAIN_LIBRARY",
>         >           "value":
>         > "C:/src/vcpkg/installed/x64-windows/debug/lib/qt5keychaind.lib",
>         >           "type": "FILEPATH"
>         >           "name": "QWT_LIBRARY",
>         >           "value":
>         "C:/src/vcpkg/installed/x64-windows/debug/lib/qwtd.lib",
>         >           "type": "FILEPATH"
>         >           "name": "SPATIALINDEX_LIBRARY",
>         >           "value":
>         "C:/src/vcpkg/installed/x64-windows/debug/lib/spatialindex-64d.lib",
>         >           "type": "FILEPATH"
>         > *From:*i-s-o <46.i.s.o.64 at gmail.com
>         <mailto:46.i.s.o.64 at gmail.com>>
>         > *Sent:* Saturday, January 30, 2021 5:58 PM
>         > *Cc:* qgis-developer <QGIS-Developer at lists.osgeo.org
>         <mailto:QGIS-Developer at lists.osgeo.org>>
>         Studio 2019 CE
>         > and vcpkg
>         > I am very interested in trying out your solution. Could you
>         share the
>         > required steps?
>         > Thx.
>         > On Fri, Jan 29, 2021, 09:25 Uhrig, Stefan
>         <stefan.uhrig at sap.com <mailto:stefan.uhrig at sap.com>
>         > <mailto:stefan.uhrig at sap.com <mailto:stefan.uhrig at sap.com>>>
>         wrote:
>         >     TL;DR: It is currently possible to build the QGIS core app
>         with
>         >     Visual Studio 2019 and vcpkg, which makes debugging QGIS
>         >     dependencies easy.
>         >     Hi all,
>         >     Some time ago I discovered vcpkg
>         >     (https://github.com/microsoft/vcpkg). vcpkg is a package
>         manager
>         >     that downloads package source code to your local machine
>         and builds
>         >     the package locally. Recently, I discovered that vcpkg
>         should be
>         >     able to provide all dependencies to build at least the
>         QGIS core
>         >     application. Hence, I gave it a try.
>         >     Basically, it worked out of the box. I started with a
>         fresh Windows
>         >     10 installation, installed Visual Studio 2019 Community
>         Edition,
>         >     Git, vcpkg, Python 3 and flex and bison for Windows. I
>         fetched all
>         >     other dependencies via vcpkg. It was not necessary to even
>         touch a
>         >     single file in the repository. I could just open the main
>         >     CMakeLists.txt file in Visual Studio and only had to tweak
>         the CMake
>         >     cache (the CMake find macros that come with QGIS are not
>         aware of
>         >     vcpkg, so I had to set some paths manually). I had to
>         switch off
>         >     some extensions though as the required dependencies were not
>         >     available via vcpkg (WITH_BINDINGS, WITH_QGIS_PROCESS,
>         >     WITH_QTWEBKIT). The build did not report any errors, I
>         could start
>         >     the application and it seems to work, but I did some light
>         testing only.
>         >     I mainly tried it because I enjoy debugging with Visual
>         Studio more
>         >     than with gdb (or gdb wrapped in some IDE). In my
>         experience, the
>         >     performance of the Visual Studio debugger is better and it
>         is more
>         >     stable, especially in long debug sessions.
>         >     I don’t want to promote official building support of QGIS with
>         >     vcpkg. Providing the dependencies via OSGeo4W is much more
>         reliable.
>         >     However, if you don’t mind the experimental nature of this
>         setup and
>         >     you want to be able to debug into QGIS’ dependencies, you
>         might give
>         >     it a try. Especially, if you want to track the cause of a
>         crash in
>         >     one of QGIS’ dependencies, this setup might be helpful.
>         You have the
>         >     source code and debug versions of the dependencies, so the
>         debugger
>         >     will jump to the crashing code line and you can inspect
>         all the
>         >     variables of the dependency.
>         >     If someone is interested in trying it, give me a note. I
>         can then
>         >     assemble detailed instructions on how to make it work. It
>         took me a
>         >     while to figure out which packages are needed and how the
>         CMake
>         >     cache needs to be tweaked.
>         >     Best regards,
>         >     Stefan
>         >     _______________________________________________
>         >     QGIS-Developer mailing list
>         >     List info:
>         https://lists.osgeo.org/mailman/listinfo/qgis-developer
>         >     Unsubscribe:
>         > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>         > Unsubscribe:
>         J. Gustavo
>         Jorge Gustavo Rocha
>         Departamento de Informática
>         Universidade do Minho
>         4710-057 Braga
>         Gabinete 3.29 (Piso 3)
>         Tel: +351 253604480
>         Fax: +351 253604471
>         Móvel: +351 910333888
>         skype: nabocudnosor
>         Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>     QGIS-Developer at lists.osgeo.org <mailto:QGIS-Developer at lists.osgeo.org>
J. Gustavo
Jorge Gustavo Rocha
4710-057 Braga
Tel: +351 253604480
Fax: +351 253604471
skype: nabocudnosor
More information about the QGIS-Developer mailing list
