[QGIS-Developer] Function to generate uri from settings in QGIS
Etienne Trimaille etienne.trimaille at gmail.com
Sat Jan 9 19:10:32 PST 2021
The connection API is indeed convenient for that :
metadata = QgsProviderRegistry.instance().providerMetadata('postgres')
connection = metadata.findConnection("the postgis connection name")
uri = QgsDataSourceUri(connection.uri())
Le sam. 9 janv. 2021 à 22:36, Alessandro Pasotti <apasotti at gmail.com> a
écrit :
> Hi Bo,
> you may have a look to
> https://qgis.org/pyqgis/master/core/QgsProviderRegistry.html?highlight=decodeuri#qgis.core.QgsProviderRegistry.decodeUri
> and encodeUri.
> Or better: the connections API
> https://qgis.org/pyqgis/master/core/QgsAbstractProviderConnection.html
> On Sat, Jan 9, 2021 at 2:03 PM Bo Victor Thomsen
> <bo.victor.thomsen at gmail.com> wrote:
> > Ok, this has me stumped.
> > I know, that I can generate a database URI like this  (example from
> cookbook):
> > uri = QgsDataSourceUri()
> > # set host name, port, database name, username and password
> > uri.setConnection("localhost", "5432", "dbname", "johny", "xxx")
> > # set database schema, table name, geometry column and optionally
> > # subset (WHERE clause)
> > uri.setDataSource("public", "roads", "the_geom", "cityid = 2643")
> > vlayer = QgsVectorLayer(uri.uri(False), "layer name you like",
> "postgres")
> > But I would like to use information from a already defined Datasource
> connection from the Datamanager dialog.
> > I suspect, that there must be a
> "QgsSettingsConvertToUri_or_whatever_it_is_called()" function that uses a
> QGS settings address  (ex. like "/PostgreSQL/connections/MyDatabase" for a
> Postgresql database connection)  as input and automatically convert the
> settings values to a URI string.
> > Is there anyone, that can point me in the right direction ?
> > Med venlig hilsen / Kind regards
> > Bo Victor Thomsen
> > QGIS-Developer mailing list
> > QGIS-Developer at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Alessandro Pasotti
> QCooperative:  www.qcooperative.net
> ItOpen:   www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210110/570c0282/attachment.html>
More information about the QGIS-Developer mailing list
