[QGIS-Developer] Travis failing in QGIS-Documentation
Matthias Kuhn matthias at opengis.ch
Tue Jan 12 04:18:11 PST 2021
Hi
The mapCanvas has already been mocked into the testing iface, it should be
fairly simple to do the same for the temporal controller.
See here for reference
https://github.com/qgis/QGIS/blob/master/python/testing/mocked.py#L58-L60
To complete the comments by Alessandro, there are also advantages of
mocking dependencies, most notably test isolation.
Regards
Matthias
On Tue, Jan 12, 2021 at 12:46 PM Alessandro Pasotti <apasotti at gmail.com>
wrote:
> On Tue, Jan 12, 2021 at 12:38 PM Richard Duivenvoorde
> <rdmailings at duif.net> wrote:
> > On 1/12/21 12:32 PM, Alessandro Pasotti wrote:
> > > On Tue, Jan 12, 2021 at 11:51 AM Richard Duivenvoorde
> > >> but... one of my docs (temporal navigator) PR's is still failing:
> > >> https://travis-ci.org/github/qgis/QGIS-Documentation/builds/739861175
> > >> NOT image related, but if somebody finds some time to check, please
> let me know what I'm doing wrong.
> > > I think this is None:
> > > navigator = iface.mapCanvas().temporalController()
> > > I wonder if it would be better to use a full real QGIS for doc
> > > testing, the same system we use for plugins testing as explained here:
> https://github.com/qgis/QGIS/tree/master/.docker#running-unit-tests-inside-qgis
> > I thought we did that?
> https://github.com/qgis/QGIS-Documentation/blob/release_3.16/doctest.dockerfile
> > don't we use that docker to have a 'real' QGIS?
> We do, but we are running doctests using python directly, not invoking
> QGIS and running the tests inside it.
> To elaborate what a "real QGIS" means in this context there are (at
> least) two ways of running tests:
> 1. the way we use for all Travis CI tests in core: run the tests
> directly from python using a mocked QgsApplication and iface, in this
> case we are using the "real QGIS" libraries but not the "real QGIS
> application"
> 2. the way I originally developed for Python plugins CI in Boudless
> (I'm not using that personally anymore) which was to run Python tests
> **inside** a "real QGIS" application.
> The advantage of (2) is that there is no need to mock anything, the
> tests are run as if you were inside QGIS and using the QGIS Python
> console.
> The disadvantage is that it is slower.
> Alessandro Pasotti
> QCooperative:  www.qcooperative.net
> ItOpen:   www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210112/22b29e3f/attachment.html>
More information about the QGIS-Developer mailing list
