[QGIS-Developer] undefined symbol: GDALAutoCreateWarpedVRTEx
Jorge Gustavo Rocha
jgr at di.uminho.pt
Tue Jan 19 03:11:51 PST 2021
Hi Even,
Thanks for the feedback. You are absolutely right. My test scripts were
introducing a dependency that install the old libgdal26.
Easy to fix, after your feedback.
Regards,
Jorge
Às 10:06 de 19/01/21, Even Rouault escreveu:
> On mardi 19 janvier 2021 09:55:46 CET Jorge Gustavo Rocha wrote:
>> Hi,
>> Just an additional comment. The GDALAutoCreateWarpedVRTEx is there, as
>> far as I can see.
>> nm -g libqgis_core.so.3.16.3 | grep GDALAutoCreateWarpedVRTEx
>> U GDALAutoCreateWarpedVRTEx
>> But if the symbol is defined in the library, why do I get this error?
> The U means undefined. Which is expected. libqgis_core imports the symbol from
> libgdal.
> What I suspect here is that QGIS is built against a libgdal 3.2.x (QGIS only
> tries to use GDALAutoCreateWarpedVRTEx if GDAL headers are >= 3.2), but at
> runtime links against an older one.
> Even
J. Gustavo
Jorge Gustavo Rocha
Departamento de Informática
Universidade do Minho
4710-057 Braga
Gabinete 3.29 (Piso 3)
Tel: +351 253604480
Fax: +351 253604471
Móvel: +351 910333888
skype: nabocudnosor
