[QGIS-Developer] crssync issues
Andreas Neumann a.neumann at carto.net
Thu Jan 21 08:26:23 PST 2021
Since a few weeks I can't compile QGIS anymore. It always hangs at
crssync (core dumped) during compile and then stops compiling.
Could there be an issue with the proj library version I have? I tried
with versions 7.2.0 and 7.2.1.
Here is the output I usually get:
[41/3286] Running crssync
FAILED: src/crssync/CMakeFiles/synccrsdb
cd /home/an/dev/QGIS/build/src/crssync &&
/home/an/dev/QGIS/build/output/bin/crssync
free(): invalid pointer
Aborted (core dumped)
ninja: build stopped: subcommand failed.
Thank you very much for you help!
Andreas
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210121/5e74397a/attachment.html>
More information about the QGIS-Developer mailing list
