[QGIS-Developer] Building QGIS with Visual Studio 2019 CE and vcpkg
i-s-o 46.i.s.o.64 at gmail.com
Sat Jan 30 08:57:58 PST 2021
I am very interested in trying out your solution. Could you share the
required steps?
Thx.
On Fri, Jan 29, 2021, 09:25 Uhrig, Stefan <stefan.uhrig at sap.com> wrote:
> TL;DR: It is currently possible to build the QGIS core app with Visual
> Studio 2019 and vcpkg, which makes debugging QGIS dependencies easy.
> Hi all,
> Some time ago I discovered vcpkg (https://github.com/microsoft/vcpkg).
> vcpkg is a package manager that downloads package source code to your local
> machine and builds the package locally. Recently, I discovered that vcpkg
> should be able to provide all dependencies to build at least the QGIS core
> application. Hence, I gave it a try.
> Basically, it worked out of the box. I started with a fresh Windows 10
> installation, installed Visual Studio 2019 Community Edition, Git, vcpkg,
> Python 3 and flex and bison for Windows. I fetched all other dependencies
> via vcpkg. It was not necessary to even touch a single file in the
> repository. I could just open the main CMakeLists.txt file in Visual Studio
> and only had to tweak the CMake cache (the CMake find macros that come with
> QGIS are not aware of vcpkg, so I had to set some paths manually). I had to
> switch off some extensions though as the required dependencies were not
> available via vcpkg (WITH_BINDINGS, WITH_QGIS_PROCESS, WITH_QTWEBKIT). The
> build did not report any errors, I could start the application and it seems
> to work, but I did some light testing only.
> I mainly tried it because I enjoy debugging with Visual Studio more than
> with gdb (or gdb wrapped in some IDE). In my experience, the performance of
> the Visual Studio debugger is better and it is more stable, especially in
> long debug sessions.
> I don’t want to promote official building support of QGIS with vcpkg.
> Providing the dependencies via OSGeo4W is much more reliable. However, if
> you don’t mind the experimental nature of this setup and you want to be
> able to debug into QGIS’ dependencies, you might give it a try. Especially,
> if you want to track the cause of a crash in one of QGIS’ dependencies,
> this setup might be helpful. You have the source code and debug versions of
> the dependencies, so the debugger will jump to the crashing code line and
> you can inspect all the variables of the dependency.
> If someone is interested in trying it, give me a note. I can then assemble
> detailed instructions on how to make it work. It took me a while to figure
> out which packages are needed and how the CMake cache needs to be tweaked.
> Best regards,
> Stefan
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210130/eea04559/attachment.html>
More information about the QGIS-Developer mailing list
