[QGIS-Developer] Question on @atlas_featureid
Alexandre Neto senhor.neto at gmail.com
Thu Jul 8 02:43:31 PDT 2021
As far as I remember @atlas_featureid has always returned the same as the
$id in the attributes table, which is kind of the internal row number.
Alex
A quinta, 8/07/2021, 10:35, Andreas Neumann <andreas at qgis.org> escreveu:
> HI Jürgen,
> Yes - I provided the primary key column
> Here is my data source string:
> service='edit' authcfg=sogis00 key='t_id' srid=2056 type=Polygon
> checkPrimaryKeyUnicity='1'
> table="alw_strukturverbesserungen"."projekt_aggregiert_v"
> (geometrie_convex_hull) sql=geometrie_bbox IS NOT NULL
> @atlas_featureid returns something like an internal "row number" or
> similar, but not the column "t_id" as defined in the data source string.
> Andreas
> On Thu, 8 Jul 2021 at 10:42, Jürgen E. Fischer <jef at norbit.de> wrote:
>> Hi Andreas,
>> On Thu, 08. Jul 2021 at 10:30:08 +0200, Andreas Neumann wrote:
>> > attribute(@atlas_feature,'pkey_name'), but it is a little more
>> complicated
>> > than @atlas_featureid - and I'm pretty sure that @atlas_featureid was
>> using
>> > the pkey column in th past?
>> > My data source for the atlas coverage layer is a Postgis View.
>> It's probably not using the column you expect for the feature id.  Did you
>> specify the key column when adding the view?
>> Jürgen
>> Jürgen E. Fischer           norBIT GmbH             Tel.
>> +49-4931-918175-31
>> Dipl.-Inf. (FH)             Rheinstraße 13          Fax.
>> +49-4931-918175-50
>> Software Engineer           D-26506 Norden
>> https://www.norbit.de
>> QGIS release manager (PSC)  Germany                 IRC: jef on
>> Libera|OFTC
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Andreas Neumann
> QGIS.ORG board member (treasurer)
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210708/40090b24/attachment.html>
More information about the QGIS-Developer mailing list
