[QGIS-Developer] Build failure in master
Tim Sutton tim at kartoza.com
Thu Jul 8 13:59:54 PDT 2021
Thanks for testing Werner. A few others on Telegram also reported that
things are building fine for them. I will try doing  clean build tomorrow,
thanks!
Regards
Tim
On Thu, Jul 8, 2021 at 1:01 PM Werner Macho <werner.macho at gmail.com> wrote:
> Hi Tim,
> Just updated master and also tried to build with no errors whatsoever.
> (Using ninja and ccache)
> Maybe try a clean build?
> regards
> Werner
> On Thu, Jul 8, 2021 at 1:10 PM Tim Sutton <tim at kartoza.com> wrote:
>> Hi All
>> Just updated to master and getting a build error:
>> Consolidate compiler generated dependencies of target
>> python_module_qgis__analysis
>> [ 68%] Linking CXX shared module ../output/python/qgis/_analysis.so
>> /usr/bin/ld:
>> CMakeFiles/python_module_qgis__analysis.dir/analysis/sip_analysispart13.cpp.o:/home/timlinux/dev/cpp/QGIS-QtCreator-Build/python/analysis/sip_analysispart13.cpp:138:
>> multiple definition of `sipTypeDef__analysis_QgsAnalysis';
>> CMakeFiles/python_module_qgis__analysis.dir/analysis/sip_analysispart12.cpp.o:/home/timlinux/dev/cpp/QGIS-QtCreator-Build/python/analysis/sip_analysispart12.cpp:1812:
>> first defined here
>> collect2: error: ld returned 1 exit status
>> gmake[2]: ***
>> [python/CMakeFiles/python_module_qgis__analysis.dir/build.make:1101:
>> output/python/qgis/_analysis.so] Error 1
>> gmake[1]: *** [CMakeFiles/Makefile2:6919:
>> python/CMakeFiles/python_module_qgis__analysis.dir/all] Error 2
>> gmake[1]: *** Waiting for unfinished jobs....
>> Consolidate compiler generated dependencies of target qgis_gui
>> [ 78%] Built target qgis_gui
>> gmake: *** [Makefile:166: all] Error 2
>> 12:03:00: The process "/usr/bin/cmake" exited with code 2.
>> Error while building/deploying project qgis (kit: Qt 5.15.2 (qt5))
>> When executing step "Build"
>> Is it because of the new exif alg maybe?
>> Regards
>> Tim
>> Tim Sutton
>> Visit http://kartoza.com to find out about open source:
>>  * Desktop GIS programming services
>>  * Geospatial web development
>> * GIS Training
>> * Consulting Services
>> Tim is a member of the QGIS Project Steering Committee
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Tim Sutton
* GIS Training
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210708/b589361f/attachment.html>
More information about the QGIS-Developer mailing list
