[QGIS-Developer] GDAL-warp and gdal-translate strange behaviour regarding output NODATA vaue
Even Rouault even.rouault at spatialys.com
Thu Jul 8 20:25:26 PDT 2021
By design, only speaking about behaviour of the GDAL utilities themselves:
- gdal_translate -a_nodata just modifies the nodata metadata, and
doesn't alter pixel values
- gdalwarp [-srcnodata xxx] -dstnodata yyy modifies the nodata metadata
and pixel values
Le 09/07/2021 à 01:02, Alexandre Neto a écrit :
> Hi,
> I was quite surprised with the behavior of gdal_translate (in clip
> raster by extent) and gdal_warp (reproject) when the user sets up an
> output nodata value different from the original nodata value of the
> input files.
> My intuition was telling me that by using that option, all the old
> nodata pixel values would be transferred to the new nodata values. So,
> if I have a raster with nodata = -3.40282e+38 and I use as output
> nodata value -9999, I would expect that all -3.40282e+38 pixels would
> be converted to -9999 and considered to be NODATA. But I was wrong. By
> doing this, I ended up with rasters containing pixels with actual
> -3.40282e+38 value, no longer considered as nodata.
> Is it just me that finds this unexpected?
> On the other hand, if you use the same similar option in the DGAL
> raster calculator it works as (I) expected.
> Best regards,
> Alexandre Neto
> User Support
> www.cooperative.net <http://www.cooperative.net>
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210709/c8ebd4e9/attachment-0001.html>
More information about the QGIS-Developer mailing list
