[QGIS-Developer] Using environment variables in QGIS.ini
Alexandre Neto senhor.neto at gmail.com
Tue Jul 13 01:44:54 PDT 2021
Hi Thomas,
I will check with others and let you know.
Best regards,
Alexandre Neto
A terça, 13/07/2021, 07:08, Thomas B <rdbath.regiodata at gmail.com> escreveu:
> Hi Alexandre,
>     >>This is some old stuff we wrote at Boundless, I believe it still
> applies for QGIS today.
> https://boundless-desktop.readthedocs.io/en/latest/system_admins/index.html#for-system-administrators
>     >>Both initialisation scripts and global setting file can help you
> with what you want to achieve.
> The initialisation scripts could be useful. But they don't seem to be
> merged into the QGIS repository yet.
> regards,
> Thomas
> Am Mo., 12. Juli 2021 um 10:54 Uhr schrieb Alexandre Neto <
> senhor.neto at gmail.com>:
>> Hi Bo,
>> This is some old stuff we wrote at Boundless, I believe it still applies
>> for QGIS today.
>> Both initialisation scripts and global setting file can help you with
>> (I should make sure this information is available on docs.qgis.org, but
>> I never find the time to do it...)
>> Best regards,
>> Alexandre Neto
>> User Support
>> www.qcooperative.net
>> A segunda, 12/07/2021, 08:34, Bo Victor Thomsen <
>> bo.victor.thomsen at gmail.com> escreveu:
>>> Hi Thomas -
>>> Your suggestion is actually pretty close to the solution I made -
>>>    - Standard installation of QGIS with *standard* .msi package.
>>>    - After the QGIS installation and before QGIS is started the user do
>>>    a one-time run a Python script from et central network drive -  using the
>>>    Python interpreter installed together with QGIS  which:
>>>    - Unzip a complete profile  with specific plugins and customized
>>>       parameters from a central network based repository. This profile replaces
>>>       the standard "default" profile.
>>>       - Search/replace a couple of "tokenized" values in QGIS.ini with
>>>       actual values based on username
>>> The profile and tokenized QGIS.ini is prepared by the GIS administrator
>>> The Python script is packaged in a .cmd file which is started by the
>>> user.
>>> Not a perfect solution, but doable:
>>>    - The It department is happy: No work doing specialized installations
>>>    - The GIS administrator is happy. It's a one-time piece of work for
>>>    each QGIS version to  prepare the profile and tokenize the QGIS.ini
>>>    - The user is - somewhat - happy. To finish the installation is
>>>    simply to double-click once on a file placed in a "highly visible" location.
>>>    - Any subsequent mistakes made by the user (Installation of dodgy
>>>    plugins, strange changes in setups ....) is easily repaired by running the
>>>    Python script again.
>>> Med venlig hilsen / Kind regards
>>> Bo Victor Thomsen
>>> Den 12-07-2021 kl. 03:14 skrev Thomas Gratier:
>>> Hi,
>>> I'm not aware QSettings provided by Qt can do it. Your %APPDATA% is not
>>> portable as would only work on Windows
>>> You can always try generate the QGIS.ini file using a templating system
>>> File QGIS.ini.j2 with following content
>>> Configuration\MODELS_FOLDER={{APPDATA}}\\QGIS\\QGIS3\\profiles\\default\\processing\\models
>>> Configuration\SCRIPTS_FOLDERS={{APPDATA}}\\QGIS\\QGIS3\\profiles\\default\\processing\\scripts
>>> File generate_ini.py with following content
>>> import os
>>> import jinja2
>>> templateLoader = jinja2.FileSystemLoader(searchpath="./")
>>> templateEnv = jinja2.Environment(loader=templateLoader)
>>> TEMPLATE_FILE = "QGIS.ini.j2"
>>> template = templateEnv.get_template(TEMPLATE_FILE)
>>> mydict = {
>>>     "APPDATA": os.environ.get("APPDATA")
>>> outputText = template.render(**mydict)
>>> with open('QGIS.ini', 'w') as outputfile:
>>>     outputfile.write(outputText)
>>> Then, to write your QGIS.ini file, do
>>> python3 generate_ini.py
>>> The possible deal breakers with this approach are:
>>> - you depend from jinja2, a third party Python library,
>>> - you can't later reuse the mechanism if for instance QGIS changes the
>>> QGIS.ini file later on
>>> Regards
>>> Thomas
>>> Le mar. 6 juil. 2021 à 09:18, Bo Victor Thomsen <
>>> bo.victor.thomsen at gmail.com> a écrit :
>>>> To the list -
>>>> Is there a method to use OS (Linux, Windows...) environment variables
>>>> in the QGIS.ini setup file ?
>>>> I had a number of customers asking for a method to "generalize"
>>>> QGIS.ini, so it doesn't contain any "user" specific file and directory
>>>> references, i.e
>>>> (From qgis.ini)
>>>> Configuration\MODELS_FOLDER=*C:\\Users\\Bo Victor
>>>> Thomsen\\AppData\\Roaming*
>>>> Configuration\SCRIPTS_FOLDERS=*C:\\Users\\Bo Victor
>>>> could be:
>>>> Configuration\MODELS_FOLDER=*%APPDATA%*
>>>> Configuration\SCRIPTS_FOLDERS=*%APPDATA%*
>>>> or likewise.
>>>> The ultimate reason is to have a method to distribute a "standard"
>>>> setup for QGIS, complete with plugins and specialized setup parameters.
>>>> This can be done by making a standard QGIS installation (which the IT
>>>> departments love, especially with the new .msi package) and afterwards
>>>> replace the "default" profile directory with at  directory specific for the
>>>> organisation. However, the process of making the new profile will place a
>>>> lot of file/directory references in QGIS.ini that is specific for the
>>>> super-user developing the new profile.
>>>> Bo Victor Thomsen
>>>> _______________________________________________
>>>> QGIS-Developer mailing list
>>>> QGIS-Developer at lists.osgeo.org
>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210713/c29194bd/attachment.html>
More information about the QGIS-Developer mailing list
