[QGIS-Developer] Loading many Excel-Files in QGIS with correct encoding
Andrea Giudiceandrea andreaerdna at libero.it
Thu Jul 15 14:14:48 PDT 2021
Il 15/07/2021 22:30, Nyall Dawson ha scritto:
> I don't think that's completely correct -- looking at the freexl
> documentation it seems that only some xls file versions are utf8, and
> others have a codepage indicating the encoding which needs to be read
> from the xls metadata:
Yes, of course BIFF5 (and previous versions), which is used until Excel
95, stores internally the strings with a codepage based encoding, while
BIFF8 (since Excel 98), stores them internally as UTF-16LE without the
need of codepages.
Anyway the documentation states that: "FreeXL is intended to be strictly
interoperable with SQLite and SpatiaLite, so any text string has to be
converted to UTF-8 encoding.  GNU libiconv can easily handle any
required charset conversion. So we can simply fetch the appropriate
bytes, then call iconv() as appropriate, and we'll immediately get back
the corresponding UTF-8 encoded text string."
So, if I'm not mistaken, the decoding from the proper internal codec and
the encoding to UTF-8 is handled by the FreeXL library for both
BIFF2/BIFF5 and BIFF8.
I've also tested a BIFF5 XLS using ogrinfo, and the output is UTF-8
encoded, while internally
Regards.
Andrea
More information about the QGIS-Developer mailing list
