[QGIS-Developer] geom.isValid() does not work in python
Raymond Nijssen r.nijssen at terglobo.nl
Sun Jul 18 02:46:13 PDT 2021
How can I run ths isValid() function on a geometry. I would think my
Polygon Geometry would inherit all functions from the
QgsAbstractGeometry base class, but it seems it doesn't.
wkt = 'POLYGON((-1 0, 0 1, 1 0, 0 -1, -1 0))'
geom = QgsGeometry.fromWkt(wkt)
print(isinstance(geom, QgsGeometry)) # Outputs True
print(isinstance(geom, QgsAbstractGeometry)) # Outputs False
result = geom.isValid(0) # Outputs Error
print(result)
I get:
AttributeError: 'QgsGeometry' object has no attribute 'isValid'
Is it supposed to work?
By the way, there's a geom.isGeosValid() that does work. But not a
geom.isQgisValid()...
Thanks,
Raymond
Terglobo
Fahrenheitstraat 1
5223 BJ 's-Hertogenbosch
The Netherlands
+31 (0) 6 25 31 49 83
More information about the QGIS-Developer mailing list
