[QGIS-Developer] geom.isValid() does not work in python
Andrea Giudiceandrea andreaerdna at libero.it
Sun Jul 18 23:38:09 PDT 2021
Il 19/07/2021 07:47, Raymond Nijssen ha scritto:
 > print( geom.isGeosValid() )
> geom2 = geom.constGet()
 > print( geom2.isValid() )
> geom3 = geom.get()
 > print( geom3.isValid() )
> I think geom2 and geom3 are the exact same thing. And the parameter 0 or
> 1 (or none at all) don't seem to change anything to the validation type,
> since they don't raise errors.
Hi Raymond,
for some insight of get() and constGet() in PyQGIS, please read a
previous thread [1] on the same argument.
The flags used in isValid() "indicates optional flags which control the
type of validity checking performed (corresponding to
QgsGeometry.ValidityFlags)" [2].
The only flag available is "FlagAllowSelfTouchingHoles: Indicates that
self-touching holes are permitted" [3].
isValid() was introduced in 3.8 [4] and uses GEOS to perform the
validity check.
isGeosValid(), which uses the same QgsGeometry.ValidityFlags, actaully
relies on isValid() and thus on GEOS to perform the validity check, so
they act in the same way AFAIK.
Maybe Nyall Dawson could share more light on this...
With validateGeometry() you could specify the validity check method to
use (QGIS or GEOS) beside the ValidityFlags.
Best regards.
[1]
http://osgeo-org.1560.x6.nabble.com/QGIS-Developer-Do-QgsGeometry-constGet-e-constParts-return-non-modifiable-or-modifiable-reference-in-td5457143.html
[2]
https://qgis.org/pyqgis/3.16/core/QgsAbstractGeometry.html?highlight=isvalid#qgis.core.QgsAbstractGeometry.isValid
[3]
https://qgis.org/api/classQgsGeometry.html#a9079690dc8d58af969fae36d16499923
[4] https://github.com/qgis/QGIS/pull/9293
More information about the QGIS-Developer mailing list
