[QGIS-Developer] process bar in processing algs
matteo matteo.ghetta at gmail.com
Tue Jul 20 02:52:34 PDT 2021
Hi Pierluigi,
> can you please explain me better?
> I have self plugin that in particular part use this code
> result_grid = processing.run("native:creategrid", params_creategrid)
as explained by Prem, if you want to add the progress when you call a
"native" algorithm of QGIS within your algorithm, then you can pass to
the algorithm parameters:
result_grid = processing.run("native:creategrid", params_creategrid,
context=context, feedback=feedback)
be aware also at the `is_child` parameter. Have a look at the example:
https://docs.qgis.org/3.4/en/docs/user_manual/processing/scripts.html#extending-qgsprocessingalgorithm
if you want to add steps to the progressBar with your logic then you can
use feedback.setProgress(number) to fill the progress bar. Have a look
at the template script and you will find a fine usage
Hope this helps
Matteo
More information about the QGIS-Developer mailing list
