[QGIS-Developer] [Qgis-psc] Grant report: Rework handling of multi-layer, mixed-format datasets
kimaidou kimaidou at gmail.com
Wed Jul 28 01:45:04 PDT 2021
Thanks a lot !
Regards,
Michaël
Le mer. 28 juil. 2021 à 09:00, Tim Sutton <tim at kartoza.com> a écrit :
> Wow great work Nyall!
> Regards
> Tim
> Sent from my iPhone
> On 28 Jul 2021, at 07:43, Paolo Cavallini <cavallini at faunalia.it> wrote:
> Thanks a lot Nyall, I'm sure you did more and better work than it was
> expected. Our donors can be happy.
> Cheers.
> Il 28 luglio 2021 07:02:30 EEST, Nyall Dawson <nyall.dawson at gmail.com> ha
> scritto:
>> Hi lists,
>> Just reporting in the conclusion of the grant work: "Rework handling
>> of multi-layer, mixed-format datasets". You can read more about the
>> motivation behind this work at
>> https://github.com/qgis/QGIS-Enhancement-Proposals/issues/216
>> While the work was partly motivated as an opportunity to clean up some
>> older parts of the QGIS codebase which were fragile and had low test
>> coverage, it has also resulted in many improvements and polish in the
>> QGIS user interface. Specifically:
>> - There's a much improved dialog shown when a user has to pick from
>> multiple layers from a dataset dropped onto QGIS. The dialog will
>> populate in a background thread, avoiding the UI hangs older QGIS
>> versions experience when scanning for layers in large files. The
>> dialog shows a unified view of all layers in the dataset, regardless
>> of whether they are vector, raster or mesh layers. There's also a new
>> "filter" widget allowing users to quickly find matching layers in
>> larger datasets.
>> - The browser view of files and file-based datasources has been
>> reworked. You'll no longer see duplicate entries for the same files
>> when these files can be read as either raster/vector/mesh layers (e.g.
>> for netcdf files, geopdf files and other mixed-format types). A lot of
>> consistency has been added to the right click actions you see when
>> interacting with file based items, with many bugs fixed along the way.
>> Under the hood, we've now got a flexible API for querying sublayers of
>> a dataset which can be easily extended to new providers so that they
>> automatically participate in the unified sublayers dialog and browser
>> items. It's all protected by a huge number of new unit tests, the
>> majority of which cover critical functionality which was previously
>> not being tested.
>> Thanks for funding this work!
>> Nyall
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Sorry for being short_______________________________________________
> Qgis-psc mailing list
> Qgis-psc at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/qgis-psc
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210728/638971b4/attachment-0001.html>
More information about the QGIS-Developer mailing list
