[QGIS-Developer] PyQt issue when building QGIS with python
Tim Sutton tim at kartoza.com
Wed Jun 23 14:54:23 PDT 2021
Oh that is odd. I will double check I have the positioning library on my computer tomorrow.
Regards
Tim
Tim Sutton
Kartoza Co-founder
tim at kartoza.com (mailto:tim at kartoza.com)
https://kartoza.com
On Jun 23 2021, at 10:52 pm, Vincent Cloarec <vcloarec at gmail.com> wrote:
> yes, fixed with the same way than Tudor.
> Update issue, sorry for the noise
> Le mer. 23 juin 2021 à 17:48, Tim Sutton <tim at kartoza.com (mailto:tim at kartoza.com)> a écrit :
> > Hi
> > I also have issues though I believe I do have the positioning lib installed. I made a dump of the error messages I get when building here:
> > https://gist.github.com/timlinux/cb1e4ae81b536bf4dae50da43f61c980
> > We chatted about this on Telegram and Richard (building on debian with Qt 5.15.2) can build fine, for me on Pop_os! it fails (Qt 5.15.0). On my Fedora 34 laptop 5.15.2 it builds fine. If it is indeed a new requirement for 5.15.2 could we reconsider this requirement please?
> > Regards
> > Tim
> > Tim Sutton
> > Kartoza Co-founder
> > https://kartoza.com
> > On Jun 23 2021, at 9:19 pm, Tudor Bărăscu <tudorbarascu at yahoo.com (mailto:tudorbarascu at yahoo.com)> wrote:
> > > Hi,
> > > I think I had the same error thtese last few days, fixed it with apy install python3-pyqt5.qtpositioning on debian.
> > > All the best,
> > > Tudor
> > > Sent from my iPhone
> > > > On 23 Jun 2021, at 22:42, Vincent Cloarec <vcloarec at gmail.com (mailto:vcloarec at gmail.com)> wrote:
> > > > Hi all,
> > > > Since few days, it is not possible for me to build QGIS with python binding. I've got this error and many others like this:
> > > > FAILED: python/plugins/db_manager/ui_DlgExportVector.py
> > > > cd /home/vincent/dev/building/build-QGIS-Debug/python/plugins/db_manager && /home/vincent/dev/sources/QGIS/scripts/pyuic_wrapper.sh /usr/bin/pyuic5 /home/vincent/dev/building/build-QGIS-Debug/output/lib /home/vincent/dev/building/build-QGIS-Debug/output/python /usr/bin/python3.8 /home/vincent/dev/sources/QGIS/python/plugins/db_manager/ui/DlgExportVector.ui -o /home/vincent/dev/building/build-QGIS-Debug/python/plugins/db_manager/ui_DlgExportVector.py
> > > > An unexpected error occurred.
> > > > Check that you are using the latest version of PyQt5 and send an error report to
> > > > support at riverbankcomputing.com (mailto:support at riverbankcomputing.com), including the following information:
> > > > * your version of PyQt (5.14.1)
> > > > * the UI file that caused this error
> > > > * the debug output of pyuic5 (use the -d flag when calling pyuic5)
> > > > Any direction I can explore ?
> > > > Thanks
> > > > Vincent
> > > > _______________________________________________
> > > > QGIS-Developer mailing list
> > > > QGIS-Developer at lists.osgeo.org (mailto:QGIS-Developer at lists.osgeo.org)
> > > > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> > > > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210623/55d2d796/attachment.html>
More information about the QGIS-Developer mailing list
