[QGIS-Developer] PyQt issue when building QGIS with python
Richard Duivenvoorde rdmailings at duif.net
Wed Jun 23 23:30:00 PDT 2021
On 6/23/21 9:42 PM, Vincent Cloarec wrote:
> Hi all,
> Since few days, it is not possible for me to build QGIS with python binding. I've got this error and many others like this:
> FAILED: python/plugins/db_manager/ui_DlgExportVector.py
> cd /home/vincent/dev/building/build-QGIS-Debug/python/plugins/db_manager && /home/vincent/dev/sources/QGIS/scripts/pyuic_wrapper.sh /usr/bin/pyuic5 /home/vincent/dev/building/build-QGIS-Debug/output/lib /home/vincent/dev/building/build-QGIS-Debug/output/python /usr/bin/python3.8 /home/vincent/dev/sources/QGIS/python/plugins/db_manager/ui/DlgExportVector.ui -o /home/vincent/dev/building/build-QGIS-Debug/python/plugins/db_manager/ui_DlgExportVector.py
> An unexpected error occurred.
> Check that you are using the latest version of PyQt5 and send an error report to
> support at riverbankcomputing.com <mailto:support at riverbankcomputing.com>, including the following information:
>   * your version of PyQt (5.14.1)
>   * the UI file that caused this error
>   * the debug output of pyuic5 (use the -d flag when calling pyuic5)
I know (from the QGIS Telegram group) that Tim has the same issues... with PopOS, but able to build on Fedora (and I am on Debian Testing)...
He also had problems with python plugins db_manager and plugin_installer...
Regards,
Richard
More information about the QGIS-Developer mailing list
