[QGIS-Developer] OSGeo4W v2 Network Installer QGIS/GRASS issue
Andrea Giudiceandrea andreaerdna at libero.it
Thu Jun 24 08:48:56 PDT 2021
Giuseppe Baiamonte wrote Tue Jun 22 06:51:57 PDT 2021
> After performing a fresh installation of QGIS on a PC running Windows 10
> Pro using the new OSGeo4W v2 Network Installer:
> - GRASS 7.8.5 is correctly installed but not working in QGIS;
> - qgis-grass-plugin is installed but not working in QGIS;
> - qgis-grass-plugin7 is not available in the installer;
> - No shortcut(s) "with GRASS" created.
> - qgis-bin-g7.exe is not present in the installation directory.
Hi Giuseppe,
new packages versions are now available in the OSGeo4W v2 repository.
If GRASS in QGIS still doesn't work with the new packages versions, I
think you can also report the issue opening a "ticket" on
https://trac.osgeo.org/osgeo4w/
Best regards.
Andrea
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210624/bb9f27aa/attachment.html>
More information about the QGIS-Developer mailing list
