[QGIS-Developer] Custom processing script instabilities (Nzl_T)
Nyall Dawson nyall.dawson at gmail.com
Fri Jun 25 23:47:18 PDT 2021
On Fri, 25 Jun 2021 at 20:14, Nazli Turini [BBA]
<nazli.turini at broadband-academy.de> wrote:
> Hi Evereybody,
> I am facing the same issue.
> I am creating a custom processing algorithm in which it loads 1, the google satellite 2. get my study_region.shp file 3. loop through the features in study_region.shp 4. and for each feature create the mbtiles using processing.run('qgis:tilesxyzmbtiles'...)5. Save the result on the predefined folder.
> The script runs when the ZOOM_MAX and ZOOM_MIN are 12. When I change the ZOOM_MAX to 19, the processing window vanished and qgis crashed. Maybe it gets some hint to @ Alexis
Your script uses a lot of thread-unsafe calls. I've marked them below.
You should find alternatives for these, or make sure your algorithm
returns the FlagNoThreading flag from an override of the
QgsProcessingAlgorithm.flags() method.
>         #if Projektnummer.find(SEPARATOR) > 0:
>         output_path = os.path.join(out_folder, Projektnummer)
>         #Projektnummer = path.basename(Projektnummer)
>             # Create folder if not present
>         if not os.path.exists(output_path):
>             makedirs(output_path)
>         #Load the google xyz data
>         urlWithParams = 'type=xyz&url=https://mt1.google.com/vt/lyrs%3Ds%26x%3D%7Bx%7D%26y%3D%7By%7D%26z%3D%7Bz%7D&zmax=19&zmin=0'
>         rlayer = QgsRasterLayer(urlWithParams, 'Google', 'wms')
>         QgsProject.instance().addMapLayer(rlayer, False)
not thread safe -- you CANNOT interact with QgsProject.instance() from
a background thread.
>         layerTree = iface.layerTreeCanvasBridge().rootGroup()
NOT thread safe -- iface methods should only ever be accessed from the
main (gui) thread.
>         layerTree.insertChildNode(0, QgsLayerTreeLayer(rlayer))
not thread safe -- the QgsLayerTree classes must be accessed only from
the thread which the parent QgsProject belongs to.
>         if feedback.isCanceled():
>             return {}
>         input_featuresource = self.parameterAsSource(parameters, 'Ausbaugebiet', context)
>         for feature in input_featuresource.getFeatures():
>             attrs = feature.attributes()
>             name=attrs[1]
>             bbox = feature.geometry().boundingBox()
>             bbox_extent = '%f,%f,%f,%f' % (bbox.xMinimum(), bbox.xMaximum(), bbox.yMinimum(), bbox.yMaximum())
>             alg_params = {
>             'BACKGROUND_COLOR': QColor(0, 0, 0, 0),
>             'DPI': 300,
>             'EXTENT': bbox_extent,
>             'METATILESIZE': 6,
>             'QUALITY': 75,
>             'TILE_FORMAT': 0,
>             'ZOOM_MAX': 12,
>             'ZOOM_MIN': 12,
>             'OUTPUT_FILE': output_path+'/googlestallite_%s.mbtiles' %(name)
>             google=processing.run('qgis:tilesxyzmbtiles', alg_params,is_child_algorithm=True,context=context, feedback=feedback)['OUTPUT_FILE']
>                     # Check for cancelation
>                 return {}
>             #Remove the layer
>         QgsProject.instance().removeMapLayers([rlayer.id()])
Again, not thread safe.
Hope that helps!
Nyall
>         del rlayer
>         return result
> Thank you so much and best regards,
> Nazli
> -----Ursprüngliche Nachricht-----
> Von: QGIS-Developer <qgis-developer-bounces at lists.osgeo.org> Im Auftrag von qgis-developer-request at lists.osgeo.org
> Gesendet: Freitag, 25. Juni 2021 09:15
> An: qgis-developer at lists.osgeo.org
> Betreff: QGIS-Developer Digest, Vol 188, Issue 36
> Send QGIS-Developer mailing list submissions to
> To subscribe or unsubscribe via the World Wide Web, visit
>         https://lists.osgeo.org/mailman/listinfo/qgis-developer
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
>         qgis-developer-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific than "Re: Contents of QGIS-Developer digest..."
> Today's Topics:
>    1. Custom processing script instabilities (Alexis R.L.)
>    2. Re: Custom processing script instabilities (Luigi Pirelli)
>    3. Re: Custom processing script instabilities (Alexis R.L.)
>    4. Re: Custom processing script instabilities (Luigi Pirelli)
> Message: 1
> Date: Thu, 24 Jun 2021 15:50:54 -0400
> From: "Alexis R.L." <alroyliz0 at gmail.com>
> To: qgis-developer <qgis-developer at lists.osgeo.org>
> Subject: [QGIS-Developer] Custom processing script instabilities
> Message-ID:
>         <CAOM0XWDiy-WUXQrL4fEFXKxUyzBb-K9Mix3kBTRwK4nnRAhHww at mail.gmail.com>
> Content-Type: text/plain; charset="utf-8"
> Greetings,
> I have one custom script that uses PIL to get the exif tag, and when I execute the script for the first time, the processing window vanishes and qgis stall and then crashes.
> To get it to run properly I had to set the return before opening the files with PIL to run a neutered version and then subsequent runs were flawless during that qgis instance.
> I ended up using a standalone exif reader, though slower , but there are no more crashes.
> Has anyone else had similar issues and is anyone aware of a way to prevent such crashes or handle them more gracefully, as no trace is left currently.
> Thanks and have a nice day,
> Alex
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210624/d49ff6b4/attachment-0001.html>
> Message: 2
> Date: Thu, 24 Jun 2021 22:34:01 +0200
> From: Luigi Pirelli <luipir at gmail.com>
> To: "Alexis R.L." <alroyliz0 at gmail.com>
> Cc: qgis-developer <qgis-developer at lists.osgeo.org>
> Subject: Re: [QGIS-Developer] Custom processing script instabilities
> Message-ID:
>         <CAFO80_qOK0pBn1KajrPN0paAF=+SrsObeLs=QGqoY_vs=Oq3XQ at mail.gmail.com>
> hard to say something without reading the code... btw generally you do not have to interact with main GUi from a processing alg that by default run in a separated thread => this can cause crash if you do not use standard processing libs (e.g. feedback) to send message to the user.
> No idea if this could be the source of the problem., IMHO sharing the code would help and also help to verify if it can be replicable.
> regards
> Luigi Pirelli
> * LinkedIn: https://www.linkedin.com/in/luigipirelli
> * Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
> * GitHub: https://github.com/luipir
> * Book: Mastering QGIS3 - 3rd Edition
> <https://www.packtpub.com/eu/application-development/mastering-geospatial-development-qgis-3x-third-edition>
> * Hire a team: http://www.qcooperative.net
> On Thu, 24 Jun 2021 at 21:51, Alexis R.L. <alroyliz0 at gmail.com> wrote:
> > Greetings,
> > Alex
> > QGIS-Developer at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210624/084a8256/attachment-0001.html>
> Message: 3
> Date: Thu, 24 Jun 2021 17:05:09 -0400
> To: Luigi Pirelli <luipir at gmail.com>
> Message-ID:
>         <CAOM0XWB22aCNvEZ8O04yi-VATkjotqN_rHJ26rBpGC87Asv7BA at mail.gmail.com>
> Greetings Luigi,
> There were no interaction, I used glob to gather all the images in a folder, used Image.Open and then used _getexif(). But returning before this part was the only way to get a stable first run.
> Sadly I can share the code (work and IP).
> The rest of it looped through datapoints and correlated the images to the points using the exif timestamp and the geolocalisation.
> Alex
> Le jeu. 24 juin 2021 ? 16:34, Luigi Pirelli <luipir at gmail.com> a ?crit :
> > regards
> > Luigi Pirelli
> > * Stackexchange:
> >> Greetings,
> >> left currently.
> >> Alex
> URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210624/415ff84b/attachment-0001.html>
> Message: 4
> Date: Fri, 25 Jun 2021 09:14:43 +0200
> Message-ID:
>         <CAFO80_oh3NPcZE9oOaoB+0+FfhGLrKU74t71+PsYGXCw=736dw at mail.gmail.com>
> strange that a library call exit, so I would inspect if the lib faces a raise condition. I would check the code outside qgis checking if it terminates for some reason.
> Luigi Pirelli
> On Thu, 24 Jun 2021 at 23:05, Alexis R.L. <alroyliz0 at gmail.com> wrote:
> > Greetings Luigi,
> > Alex
> >> regards
> >> Luigi Pirelli
> >> * Stackexchange:
> >>> Greetings,
> >>> left currently.
> >>> Alex
> URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210625/fcd0affd/attachment.html>
> Subject: Digest Footer
> End of QGIS-Developer Digest, Vol 188, Issue 36
More information about the QGIS-Developer mailing list
