[QGIS-Developer] Reg: native:clip processing tool error with "Could not create memory layer"
Nyall Dawson nyall.dawson at gmail.com
Fri Jun 25 23:50:17 PDT 2021
On Fri, 25 Jun 2021 at 21:56, Prem Kumar <prem.netgis at gmail.com> wrote:
> Hi Team,
> I am trying to run a script which initially clips certain data and then outputs an in-memory clipped layer that will be used further in the code on the linux machine.
> The script used to work perfectly fine on both Windows and Linux machines, however, only linux machines below errors are seen off late saying output in-memory layer is not created. Suspected disk space availability issue but it is not. Any thoughts to troubleshoot would be appreciated. Thanks.
You'll need to share your script for any meaningful replies. Are you
able to do this?
Nyall
> Regards,
> Prem
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
