[QGIS-Developer] Voronoi tool missing from processing, what could be wrong?
Tim Sutton tim at kartoza.com
Tue Mar 2 15:44:02 PST 2021
Haha, thanks! You are fixing the issue faster than I can document it :-P
Regards
Tim
On Tue, Mar 2, 2021 at 11:41 PM Nyall Dawson <nyall.dawson at gmail.com> wrote:
> On Wed, 3 Mar 2021 at 09:12, Nyall Dawson <nyall.dawson at gmail.com> wrote:
> > On Wed, 3 Mar 2021 at 09:10, Tim Sutton <tim at kartoza.com> wrote:
> > > Hi
> > > Can you check if you have python-psycopg2 installed on your system? I
> had a similar issue a month or two back which was fixed by installing it.
> (Thanks for the nudge Nyall).
> > Ah -- that was the one!  I thought it was gdal for some reason...
> > flaky memory :)
> > We should really investigate why this caused a silent failure to show
> > the algorithms instead of an error...
> Or I could JFDI :P https://github.com/qgis/QGIS/pull/41985
> Nyall
> > Nyall
> > > Regards
> > > Tim
> > > On Tue, Mar 2, 2021 at 11:19 AM Hernán De Angelis <
> variablestarlight at gmail.com> wrote:
> > >> On 2021-03-02 10:51, Richard Duivenvoorde wrote:
> > >> > On 3/2/21 10:41 AM, Hernán De Angelis wrote:
> > >> >> On 2021-03-02 10:21, Nyall Dawson wrote:
> > >> >>> On Tue, 2 Mar 2021 at 18:34, Hernán De Angelis
> > >> >>> <variablestarlight at gmail.com> wrote:
> > >> >>>> Hi,
> > >> >>>> I wrote about this a few days ago in the user list but I still
> have the
> > >> >>>> problem and can find neither a cause nor a solution. I thus post
> it in
> > >> >>>> this list in the hope that some developer may have a hint on
> what is
> > >> >>>> going wrong here.
> > >> >>> Double check that you have the gdal python packages installed
> > >> >> Thanks for this,
> > >> >> from osgeo import gdal
> > >> >> just works, so I guess it is installed.
> > >> > What is the value of
> > >> > BINDINGS_GLOBAL_INSTALL
> > >> > in your compile config?
> > >> The value is "YES"
> > >> > Looks like something is not picked up with your install.
> > >> Agree
> > >> > What if you run qgis 31.8 from the 'output/bin' dir in your build
> directory?
> > >> Behaves just the same
> > >> > If all fails I would (I think) compile and set CMAKE_INSTALL_PREFIX
> in some local dir in your HOME
> > >> > I did in ~/bin/qgis_/3.18/debug (for debug build):
> > >> > And create a startup script like
> > >> > export
> LD_LIBRARY_PATH=~/bin/qgis_/3.18/debug/lib/:/usr/lib/grass78/lib/
> > >> > export
> PYTHONPATH=~/bin/qgis_/3.18/debug/share/qgis/python:$PYTHONPATH
> > >> > export QGIS_DEBUG=0
> > >> > # passing ALL parameters to qgis bin
> > >> > # eg to be able to call a certain translation
> > >> > # qgis --lang nl
> > >> > ~/bin/qgis_/3.18/debug/bin/qgis "$@"
> > >> Thanks, will think about this and try it.
> > >> Thank you again for your ansers. I see I have a sort of
> linking/library
> > >> problem. GRASS is installed and GRASS modules are compiled but then
> > >> these do not appear either in the menu.
> > >> /Hernán
> > >> > Suc6
> > >> _______________________________________________
> > >> QGIS-Developer mailing list
> > >> QGIS-Developer at lists.osgeo.org
> > >> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> > >> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> > > Tim Sutton
> > > Visit http://kartoza.com to find out about open source:
> > >  * Desktop GIS programming services
> > >  * Geospatial web development
> > > * GIS Training
> > > * Consulting Services
> > > Tim is a member of the QGIS Project Steering Committee
Tim Sutton
* GIS Training
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210302/24f3e0ac/attachment-0001.html>
More information about the QGIS-Developer mailing list
