[QGIS-Developer] Reading NetCDF mesh data
Saber Razmjooei saber.razmjooei at lutraconsulting.co.uk
Tue Mar 2 21:55:05 PST 2021
Hi James,
Similar issue was reported on the MDAL repo:
https://github.com/lutraconsulting/MDAL/issues/155
ADCIRC netcdf appears not to be fully compliant with UGRID and hence you
get the error.
I hope this helps. If not, please open a ticket on MDAL and pass us some
example file and we can dig in deeper to find the issue.
Kind regards
Saber
On Tue, 2 Mar 2021 at 19:27, James McManus <jmpmcmanus at gmail.com> wrote:
> Hi - I'm using QGIS 3.16.1 to read ADCIRC NetCDF Mesh file. When I open
> the file it produces the following error statement:
> HDF5-DIAG: Error detected in HDF5 (1.10.6) thread 139951069413888:
>   #000: H5A.c line 430 in H5Aopen(): unable to load attribute info from
> object header for attribute: 'File Type'
>     major: Attribute
>     minor: Can't open object
>   #001: H5Aint.c line 433 in H5A__open(): unable to load attribute info
> from object header for attribute: 'File Type'
>     major: Attribute
>   #002: H5Oattribute.c line 497 in H5O__attr_open_by_name(): can't open
> attribute
>     major: Attribute
>   #003: H5Adense.c line 429 in H5A__dense_open(): can't locate attribute
> in name index
>     major: Attribute
>     minor: Object not found
> The file is read in properly, but do you know why I am getting this error?
> Thanks
> Jim McManus
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Saber Razmjooei
www.lutraconsulting.co.uk
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210303/9859ae3e/attachment.html>
More information about the QGIS-Developer mailing list
