[QGIS-Developer] Voronoi tool missing from processing, what could be wrong?
Tim Sutton tim at kartoza.com
Wed Mar 3 00:09:30 PST 2021
Hi
On Wed, Mar 3, 2021 at 7:58 AM Hernán De Angelis <
variablestarlight at gmail.com> wrote:
> On 2021-03-03 00:12, Nyall Dawson wrote:
> > On Wed, 3 Mar 2021 at 09:10, Tim Sutton <tim at kartoza.com> wrote:
> >> Hi
> >> Can you check if you have python-psycopg2 installed on your system? I
> had a similar issue a month or two back which was fixed by installing it.
> (Thanks for the nudge Nyall).
> > Ah -- that was the one!  I thought it was gdal for some reason...
> > flaky memory :)
> > We should really investigate why this caused a silent failure to show
> > the algorithms instead of an error...
> Yes, an error message could be beneficial. I remember from previous
> installations that QGIS would complain on opening that psycopg (or other
> python modules) weren't installed.
Yes Nyall has already taken care of it:
https://github.com/qgis/QGIS/issues/41984
Regards
Tim
> /H.
> > Nyall
> >> Regards
> >> Tim
> >> On Tue, Mar 2, 2021 at 11:19 AM Hernán De Angelis <
> >>> On 2021-03-02 10:51, Richard Duivenvoorde wrote:
> >>>> On 3/2/21 10:41 AM, Hernán De Angelis wrote:
> >>>>> On 2021-03-02 10:21, Nyall Dawson wrote:
> >>>>>> On Tue, 2 Mar 2021 at 18:34, Hernán De Angelis
> >>>>>> <variablestarlight at gmail.com> wrote:
> >>>>>>> Hi,
> >>>>>>> I wrote about this a few days ago in the user list but I still
> have the
> >>>>>>> problem and can find neither a cause nor a solution. I thus post
> it in
> >>>>>>> this list in the hope that some developer may have a hint on what
> is
> >>>>>>> going wrong here.
> >>>>>> Double check that you have the gdal python packages installed
> >>>>> Thanks for this,
> >>>>> from osgeo import gdal
> >>>>> just works, so I guess it is installed.
> >>>> What is the value of
> >>>> BINDINGS_GLOBAL_INSTALL
> >>>> in your compile config?
> >>> The value is "YES"
> >>>> Looks like something is not picked up with your install.
> >>> Agree
> >>>> What if you run qgis 31.8 from the 'output/bin' dir in your build
> directory?
> >>> Behaves just the same
> >>>> If all fails I would (I think) compile and set CMAKE_INSTALL_PREFIX
> in some local dir in your HOME
> >>>> I did in ~/bin/qgis_/3.18/debug (for debug build):
> >>>> And create a startup script like
> >>>> export
> LD_LIBRARY_PATH=~/bin/qgis_/3.18/debug/lib/:/usr/lib/grass78/lib/
> >>>> export PYTHONPATH=~/bin/qgis_/3.18/debug/share/qgis/python:$PYTHONPATH
> >>>> export QGIS_DEBUG=0
> >>>> # passing ALL parameters to qgis bin
> >>>> # eg to be able to call a certain translation
> >>>> # qgis --lang nl
> >>>> ~/bin/qgis_/3.18/debug/bin/qgis "$@"
> >>> Thanks, will think about this and try it.
> >>> Thank you again for your ansers. I see I have a sort of linking/library
> >>> problem. GRASS is installed and GRASS modules are compiled but then
> >>> these do not appear either in the menu.
> >>> /Hernán
> >>>> Suc6
> >>> _______________________________________________
> >>> QGIS-Developer mailing list
> >>> QGIS-Developer at lists.osgeo.org
> >>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> >>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> >> Tim Sutton
> >> Visit http://kartoza.com to find out about open source:
> >>   * Desktop GIS programming services
> >>   * Geospatial web development
> >> * GIS Training
> >> * Consulting Services
> >> Tim is a member of the QGIS Project Steering Committee
Tim Sutton
* GIS Training
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210303/a9526b91/attachment-0001.html>
More information about the QGIS-Developer mailing list
