[QGIS-Developer] Filter by expression in Report(s)
Bernd Vogelgesang bernd.vogelgesang at gmx.de
Wed Mar 3 10:07:47 PST 2021
Hi Matteo,
there is already a "whishlist" from Nyall concerning Reports:
** Reports **
- Expression based filters for sections
- Expression based custom sort order for field groups
- Relation based sections (repeat section for all related features)
- Support “aggregated” geometries for headers/footers in sections
- Support for non-full page repeating sections
- Support for "expanding" content (.e.g label items which grow to fit
the available text, causing the section's size to vary
feature-by-feature) (this one continues on from the previous point)
- Reorder report sections via drag and drop
- Add user-defined notes to sections describing the logic (not
included in the outputs, only visible while designing the report)
- Copy/paste groups and sections between different reports (or for
duplicating within the same report)
(from conversation on september 16 on qgis-user) and this query on
github:
https://github.com/qgis/QGIS/issues?q=is%3Aopen+is%3Aissue+label%3AReports
Have not checked yet if there was already progress on this.
Cheers,
Bernd
On 03.03.21 17:16, matteo wrote:
> Hi devs,
> I think this is a feature request, but I'm unsure. In the Report
> Layout when adding a layer in a "Field Group Sections" within another
> "Field Group Sections", the layers must have a field in common that is
> used to filter the features.
> If not, one can use the "join attributes by location" or create a
> virtual field with an aggregate expression.
> Is there any interest to add a Expression Combobox instead of a Field
> Combobox in the Report Layout to filter the features "live"?
> Or is there a simpler way I'm missing? :)
> Cheers and thanks
> Matteo
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
