[QGIS-Developer] point in polygon strikes again: big performance issue
Delaz J delazj at gmail.com
Sun Mar 14 15:36:24 PDT 2021
Hi Jorge,
It doesn't explain nor fix the issue with your expression but mind
trying /array_sum(overlay_contains('03-04-2021', 'Active'))/? No working
QGIS around to test myself.
I don't remember if array_sum was introduced in 3.18 or master but
overlay_** requires at least 3.16. Regards, Harrissou
Le 14/03/2021 à 22:47, David Strip a écrit :
> I was able to replicate your problem on my system (Win 10, QGIS 3.10.5).
> I tried "Join attributes by location (summary)". This computed the
> result in about 5 seconds.
> There are some anomalies in the data, however. For example, there's an
> entry for Belgium with province value "Unknown" and no lat/lon, so it
> doesn't get included in the total. Also, the point for Northern
> Territories, Australia, lies in the ocean, so it is not contained in
> the Australia polygon.
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210314/22350686/attachment.html>
More information about the QGIS-Developer mailing list
