[QGIS-Developer] QOCISPATIAL driver cannot be loaded
Uhrig, Stefan stefan.uhrig at sap.com
Fri Mar 19 11:38:13 PDT 2021
Hi Peter,
This usually happens if a library (qsqlocispatial.dll) is not able to load its dependencies.
I usually use Process Monitor (https://docs.microsoft.com/en-us/sysinternals/downloads/procmon) or Dependency Walker (https://www.dependencywalker.com/) to track those issues.
Are you trying to access an Oracle database? Then you might have to install the Oracle Instant Client: https://www.oracle.com/database/technologies/instant-client/winx64-64-downloads.html
Best regards,
Stefan
From: QGIS-Developer <qgis-developer-bounces at lists.osgeo.org> On Behalf Of peter.steibert at t-online.de
Sent: Friday, March 19, 2021 3:00 PM
To: qgis-developer at lists.osgeo.org
Subject: [QGIS-Developer] QOCISPATIAL driver cannot be loaded
Hello,
I just compiled the qsqlocialspatial.dll from the QGis project and tried to use it with QSqlDatabase.
QSqlDatabase db2 = QSqlDatabase::addDatabase("QOCISPATIAL");
When I startet the program it looked like the detection oft he sqldriver was successful.
QFactoryLoader::QFactoryLoader() looking at "C:/Qt/5.14.2/msvc2017_64/plugins/sqldrivers/qsqlocispatial.dll"
Found metadata in lib C:/Qt/5.14.2/msvc2017_64/plugins/sqldrivers/qsqlocispatial.dll, metadata=
    "IID": "org.qt-project.Qt.QSqlDriverFactoryInterface",
    "MetaData": {
        "Keys": [
            "QOCISPATIAL8",
            "QOCISPATIAL"
   "archreq": 0,
    "className": "QOCISpatialDriverPlugin",
    "debug": false,
    "version": 331264
Got keys from plugin meta data ("QOCISPATIAL8", "QOCISPATIAL")
Later when I tried to actually use the driver I got the following output.
QFactoryLoader::QFactoryLoader() checking directory path "C:/Users/Peter Steibert/source/repos/QtWidgetsApplication2/x64/Release/sqldrivers" ...
"QtWidgetsApplication2.exe" (Win32): "C:\Qt\5.14.2\msvc2017_64\plugins\sqldrivers\qsqlocispatial.dll" geladen. Das Modul wurde ohne Symbole erstellt.
"QtWidgetsApplication2.exe" (Win32): "C:\Windows\System32\wsock32.dll" geladen.
"QtWidgetsApplication2.exe" (Win32): "C:\Windows\System32\wsock32.dll" wurde entladen.
"QtWidgetsApplication2.exe" (Win32): "C:\Qt\5.14.2\msvc2017_64\plugins\sqldrivers\qsqlocispatial.dll" wurde entladen.
Cannot load library C:\Qt\5.14.2\msvc2017_64\plugins\sqldrivers\qsqlocispatial.dll: Das angegebene Modul wurde nicht gefunden.
QLibraryPrivate::loadPlugin failed on "C:/Qt/5.14.2/msvc2017_64/plugins/sqldrivers/qsqlocispatial.dll" : "Cannot load library C:\\Qt\\5.14.2\\msvc2017_64\\plugins\\sqldrivers\\qsqlocispatial.dll: Das angegebene Modul wurde nicht gefunden."
QSqlDatabase: QOCISPATIAL driver not loaded
QSqlDatabase: available drivers: QSQLITE QOCISPATIAL QOCISPATIAL8 QODBC QODBC3 QPSQL QPSQL7
Thanks in advance for your help
Peter
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210319/70088923/attachment.html>
More information about the QGIS-Developer mailing list
