[QGIS-Developer] asyncio in plugins?
David Marteau dmarteau at 3liz.com
Tue Mar 23 12:47:57 PDT 2021
Asynchronous python code with asyncio assume that you have an ioloop
running in a blocking way in your python code:
that means that no other code (in the same thread) cannot run
concurrently with your async tasks while your loop is running.
David
Le 23/03/2021 à 20:28, Sebastian M. Ernst a écrit :
> Hi all,
> has anyone made any (positive or negative) experiences with using
> `asyncio`-enabled [1] code in QGIS plugins?
> Best regards,
> Sebastian
> 1: https://docs.python.org/3/library/asyncio.html
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
