[QGIS-Developer] Multiprocessing QGIS
Pedro Camargo c at margo.co
Sun Mar 28 15:59:59 PDT 2021
Florian,
              I see that this is all very well developed in the C++ world, but I would like to add one question and one comment.
Question:
- Is there anything similar to Python Multiprocessing that can be used?  Sometimes releasing the GIL is hard (requires going to C++/C/Cython).  The original question may have been on this, I guess.
- Using Python threads works well when you do everything in Cython (for example) and release the GIL
Cheers,
Pedro
 ---- On Mon, 29 Mar 2021 05:00:01 +1000  <qgis-developer-request at lists.osgeo.org> wrote ----
 > Send QGIS-Developer mailing list submissions to
 >     qgis-developer at lists.osgeo.org
 > To subscribe or unsubscribe via the World Wide Web, visit
 >     https://lists.osgeo.org/mailman/listinfo/qgis-developer
 > or, via email, send a message with subject or body 'help' to
 > You can reach the person managing the list at
 >     qgis-developer-owner at lists.osgeo.org
 > When replying, please edit your Subject line so it is more specific
 > than "Re: Contents of QGIS-Developer digest..."
 > Today's Topics:
 >    1. Re: Multiprocessing QGIS (Florian El Ahdab)
 > Message: 1
 > Date: Sun, 28 Mar 2021 16:48:12 +0200
 > From: Florian El Ahdab <felahdab at gmail.com>
 > To: Joao Folgado <jfolgado94 at gmail.com>
 > Cc: David Marteau <dmarteau at 3liz.com>, qgis-developer
 >     <qgis-developer at lists.osgeo.org>
 > Subject: Re: [QGIS-Developer] Multiprocessing QGIS
 > Message-ID:
 >     <CAEeudyS4cjKzb9LTRjwyj7fovKgZpNO_hdw66eijgQXbwo61mQ at mail.gmail.com>
 > Content-Type: text/plain; charset="utf-8"
 > Hi.
 > I am posting my reply again because I missed the qgis-developer mail list
 > first...
 > It is indeed possible to achieve multiprocessing in QGIS.
 > But you should rely on Qt multi thread mechanisms rather than on the python
 > multiprocessing module.
 > Qgis is written in C++, based on the Qt library. Using the Qt
 > possibilities, even if it is thru python, is less likely to trigger
 > problems...
 > QThread is your friend here.
 > You can also use classes that are designed in QGis to ease things up, like
 > QgsTask (https://nocache.qgis.org/api/3.4/classQgsTask.html).
 > Regards
 > Florian.
 > Le sam. 27 mars 2021 ? 13:48, Joao Folgado <jfolgado94 at gmail.com> a ?crit :
 > > Hi guys,
 > > First of all thank you but, David Marteua and Sebastian Ernst, for the
 > > answer.
 > > So is impossible to use multiprocessing in Qgis plugin?
 > > This is a enormous limitations because Qgis have a lot of data  that
 > >  needs to be evaluated in same cases. Nowadays the cpu have 5,7, 9 cores
 > > and we can not use them in a plugin for example is bad. If some one have
 > > any idea who we can use multiprocessing in a plugin i will be thankful.
 > > Best regards,
 > > Jo?o Folgado
 > > David Marteau <dmarteau at 3liz.com> escreveu em sex., 26/03/2021 ?s 08:57 :
 > >> > I am not entirely sure what QGIS' (intended) behavior is in a case like
 > >> > this. From the top of my head, having read the relevant portion of its
 > >> > source code, I'd expect at least a second application window likely
 > >> > followed by non-deterministic behavior (again, depending on the
 > >> > use-case, likely resulting in a crash). Can someone elaborate?
 > >> I can confirm that the result is non-deterministic even with headless
 > >> PyQgis programs.
 > >> For programs relying heavily on multiprocessing the best strategy is to
 > >> use a `fork-server` process
 > >> started at the very beginning (before initializing Qgis) managing the
 > >> pool of child processes, so that each forked
 > >> process starts in the same state.
 > >> David,
 > >> Le 23/03/2021 ? 19:22, Sebastian M. Ernst a ?crit :
 > >> > Hi Jo?o, all,
 > >> > really interesting question.
 > >> >> however when i run the plugin a new instance of application is open
 > >> >> and give me an error.
 > >> > I assume that you are using `multiprocessing` [1] from Python's standard
 > >> > library. Its default behavior is to use process-based parallelism (as
 > >> > the title in the documentation says). I am assuming that you have not
 > >> > altered its default behavior (e.g. by configuring it to use threads
 > >> > instead). This is why you get at least another "worker" process if you
 > >> > e.g. create a process pool. I have successfully used this method with
 > >> > QGIS before, but always on Linux and OS X. I am just guessing that you
 > >> > are doing this on Windows, right?
 > >> > Depending on the operating system, `multiprocessing` uses different
 > >> > methods to create worker processes. On Linux and OS X, it simply forks
 > >> > [2] the main process. This way, you do not see a second application
 > >> > window popping up. You "simply" get a second, third, fourth, ... process
 > >> > "in the background". On Windows, the `fork` syscall does not exist,
 > >> > neither does something similar [3]. `multiprocessing` therefore starts a
 > >> > complete new process from scratch. If it was pure Python, it would
 > >> > simply start a new Python interpreter process. Because it is QGIS, it
 > >> > opens another instance of QGIS.
 > >> > Best regards,
 > >> > Sebastian
 > >> > 1: https://docs.python.org/3/library/multiprocessing.html
 > >> > 2: https://en.wikipedia.org/wiki/Fork_(system_call)
 > >> > 3: https://stackoverflow.com/q/985281/1672565
 > >> > Am 23.03.21 um 13:08 schrieb Joao Folgado:
 > >> >> Hi everyone,
 > >> >> I had created  a plugin for Qgis and I trying to optimize it. So i use
 > >> >> in my code the library python that have Queue whit multiprocessing
 > >> >> however when i run the plugin a new instance of application is open and
 > >> >> give me an error.
 > >> >> I had early use this type of multiprocessing before in simple projects
 > >> >> in university and it works ok.
 > >> >> Can someone help ? I researched in many forums, i see people whit the
 > >> >> same question but not with the answer.
 > >> >> Thank you very much.
 > >> >> Best regards,
 > >> >> Jo?o Folgado
 > >> >> Portugal
 > >> >> JO?O FOLGADO
 > >> >> _______________________________________________
 > >> >> QGIS-Developer at lists.osgeo.org
 > >> >> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
 > >> >> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
 > > JO?O FOLGADO
 > -------------- next part --------------
 > An HTML attachment was scrubbed...
 > URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210328/84f82603/attachment-0001.html>
 > Subject: Digest Footer
 > End of QGIS-Developer Digest, Vol 185, Issue 60
More information about the QGIS-Developer mailing list
