[QGIS-Developer] Disable/commenting provider filter?
Matthias Kuhn matthias at opengis.ch
Tue May 11 13:10:19 PDT 2021
Unfortunately, that won't work, filters are not part of the style.
On Tue, May 11, 2021 at 9:24 PM Alexandre Neto <senhor.neto at gmail.com>
wrote:
> As an workaround, can't you just create a new style and remove the filter?
> Then go back to the default style?
> Obviously a checkbox would be much more user friendly.
> Alexandre Neto
> A terça, 11/05/2021, 09:52, Andreas Neumann <andreas at qgis.org> escreveu:
>> Hi Richard,
>> Yes - I think this would be very useful. I would prefer the checkbox for
>> enabling/disabling without losing the filter string.
>> Thanks,
>> Andreas
>> On Mon, 10 May 2021 at 16:41, Richard Duivenvoorde <rdmailings at duif.net>
>> wrote:
>>> Hi List,
>>> When I add a filter to a layer, I often want to temporarily disable that
>>> filter (just to see what the full view is).
>>> Working a lot with sql scripts recently, in which you comment out (a
>>> part) of a sql query by putting '--' in front of it, I tried that also
>>> in the Query builder, and though it looks like I'm commenting out my
>>> query (the query is greyed-out), it's not working, I get a parsing
>>> error.
>>> So usability question:
>>> - would other people be interested in temporarily disabling the layer
>>> filter query, or am I the only one :-)
>>> If yes:
>>> - should it be implemented by 'commenting' out part of the query?
>>> - or should there be some 'temporarily disable' checkbox in the query
>>> builder)
>>> - should it be a context menu (either the layer, or the little filter
>>> overlay icon in the layermanager)
>>> Tech question:
>>> - any forseeing issues with such thing?
>>> Regards,
>>> QGIS-Developer mailing list
>>> QGIS-Developer at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Andreas Neumann
>> QGIS.ORG board member (treasurer)
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210511/5f16ea12/attachment.html>
More information about the QGIS-Developer mailing list
