[QGIS-Developer] QgsQuick removal
Peter Petrik
peter.petrik at lutraconsulting.co.uk
Thu May 13 01:50:21 PDT 2021
thanks for this agreement and I will do the changes accordingly in the
Input app and QGIS this week.
Peter
On Thu, May 13, 2021 at 10:17 AM Matthias Kuhn <matthias at opengis.ch> wrote:
> Hi Peter,
> Indeed the QgsQuick library is mostly an externalized library for input at
> the moment and I can understand the reasons for coming forward with this
> proposal.
> One of the reasons for not picking it up completely in QField was that
> some of the included components have been under heavy development on QField
> side too, sometimes with app specific changes.
> However there are some core parts which can be well mutualized and a
> collaboration was envisioned on QField side too.
> They are kept in a dedicated folder in the QField repository
> https://github.com/opengisch/QField/tree/master/src/core/qgsquick
> I think keeping these in place would be good, this way we can preserve a
> nucleus of a generic library. If you are ok with that, we'll make sure to
> integrate the latest changes from the QField repository soon.
> Thank you
> Matthias
> On Wed, May 12, 2021 at 9:51 AM Peter Petrik <
> peter.petrik at lutraconsulting.co.uk> wrote:
>> Hi devs,
>> I will be removing QgsQuick library related pieces from the qgis/QGIS
>> repository if there are no strong objections.
>> The reasons are:
>> - the release cycle for QgsQuick is different than QGIS core, more based
>> on the InputApp releases
>> - QgsQuick is not used by other projects but InputApp despite being on
>> master for few years (as far as I know)
>> - In case we would like to use Qt QML in QGIS desktop, we will probably
>> need different QML classes than for mobile devices (e.g. on mobile devices
>> you do not edit form config, etc) anyways
>> - QgsQuick library is not shipped with the regular QGIS packaging system,
>> not build/tested in the CI mostly (e.g. the tests on master are coredumping
>> ATM), so it doesn't really matured to the common QML library
>> - There is an extra maintenance of the QgsQuick (pull requests in
>> qgis/QGIS, CI setup, code maintenance, test runs) for the QGIS developers
>> and to the QGIS infrastructure as such.
>> - There is quite a maintenance cost of Lutra Team to backport the changes
>> from Input back to qgis/QGIS, keep the code in sync, test and in general
>> use a library+application split when not necessary.
>> Therefore we do not see the reasons why to spend extra time on the
>> community and us to maintain this bit. The code will be still present in
>> the https://github.com/lutraconsulting/input open-source project, so in
>> case other Qt/QGIS related mobile projects would like to build something on
>> top of it, we would be happy to cooperate.
>> Cheers,
>> Peter
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210513/40237340/attachment.html>
