[QGIS-Developer] Fail compiing WITH_3D on ubuntu 20.04 - Qt53DExtras config files missing
Denis Rouzaud denis.rouzaud at gmail.com
Mon Oct 4 05:09:35 PDT 2021
I believe you have to set this on 20.04
-DQT5_3DEXTRA_LIBRARY=/usr/lib/x86_64-linux-gnu/libQt53DExtras.so
-DQT5_3DEXTRA_INCLUDE_DIR=/root/QGIS/external/qt3dextra-headers
-DCMAKE_PREFIX_PATH=/root/QGIS/external/qt3dextra-headers/cmake
-DQt53DExtras_DIR=/root/QGIS/external/qt3dextra-headers/cmake/Qt53DExtras
https://github.com/qgis/QGIS/blob/master/.docker/docker-qgis-build.sh#L48-L51
for reference
https://qgis-developer.osgeo.narkive.com/xMSz0lbQ/building-master-with-3d-on-debian-testing-buster
Ciao,
Denis
Le lun. 4 oct. 2021 à 14:00, Alexandre Neto <senhor.neto at gmail.com> a
écrit :
> Hi,
> I have been having problems compiling QGIS with 3D support on Kubuntu
> 20.04. This is the CCMAKE configuration error:
> CMake Error at /usr/lib/x86_64-linux-gnu/cmake/Qt5/Qt5Config.cmake:28
> (find_package):
>   Could not find a package configuration file provided by "Qt53DExtras"
> with
>   any of the following names:
>     Qt53DExtrasConfig.cmake
>     qt53dextras-config.cmake
>   Add the installation prefix of "Qt53DExtras" to CMAKE_PREFIX_PATH or set
>   "Qt53DExtras_DIR" to a directory containing one of the above files.  If
>   "Qt53DExtras" provides a separate development package or SDK, be sure it
>   has been installed.
> Call Stack (most recent call first):
>   CMakeLists.txt:455 (find_package)
> I have libQt53DExtras installed, but there are no configuration files like
> for other QT5 libraries. I tried to follow the suggestion and add the
> installation prefix to CMAKE_PREFIX_PATH as suggested, but either it does
> not work, or I am doing it wrong:
> ccmake -G Ninja .. -DMAKE_PREFIX_PATH=/usr/lib/x86_64-linux-gnu/
> Anyone is facing similar problems? any hint?
> Thanks,
> Alexandre Neto
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20211004/2c8b0bbd/attachment.html>
More information about the QGIS-Developer mailing list
