[QGIS-Developer] testing processing algorithms with PostgreSQL provider
Sandro Santilli strk at kbt.io
Tue Oct 12 09:50:17 PDT 2021
While working on improved heuristics with ExtractWithinDistance
processing algorithm [1] I stumbled upon a possible bug [2] and
trying to find a good way to add a test for it.
My understanding of the "Processing Algorithms Testing" page [3]
is that the yaml files used for testing can only use FILES as inputs
to the processing algorithm, but in order for the bug I found to be
exposed I need them to use the PostgreSQL provider.
My questions are:
  - Do you confirm only files can be used as input ?
  - What's the best way to test the functionality of
    src/analysis/processing/qgsalgorithmdistancewithin.cpp
    when used against different providers ?
[1] https://github.com/qgis/QGIS/pull/45339
[2] https://github.com/qgis/QGIS/issues/45352
[3] https://docs.qgis.org/3.16/en/docs/developers_guide/processingtesting.html
--strk;
  Libre GIS consultant/developer
  https://strk.kbt.io/services.html
More information about the QGIS-Developer mailing list
