[QGIS-Developer] projected CRS
Stefan Giese (WhereGroup) stefan.giese at wheregroup.com
Wed Oct 13 21:31:45 PDT 2021
Thank you Nyall
for clarifying. After sending my answer I realized that there can be
projection which are not registered and have an official code
Best
Stefan
Am 14.10.2021 um 02:49 schrieb Nyall Dawson:
> On Wed, 13 Oct 2021 at 20:10, Stefan Giese (WhereGroup)
> <stefan.giese at wheregroup.com> wrote:
>> in python I would do it like this one:
>> l = iface.activeLayer()
>> if l.crs().authid() != "":
>>      print(l.crs().authid ())
>> else:
>>      print("No projection")
> This isn't quite right -- e.g. a geographic CRS like WGS 84 will still
> have an authid ("EPSG:4326"). As Etienne pointed out .isGeographic()
> is the correct way to test that.
> I think here you might be trying to check instead if the layer has a
> valid CRS set (as opposed to "no CRS set"), which should be tested
> instead by:
> if not l.crs().isValid():
>       print("No CRS set")
> (Also noting that a perfectly valid CRS may not have an authid if it
> came from a custom wkt definition and isn't matched to any official
> registry entry)... phew!
> Nyall
>> Am 13.10.2021 um 11:50 schrieb pierluigi de rosa:
>> Dear all,
>> mayble a very simple question.
>> Is it possible to check quickly if a layer has a projected CRS or not?
>> in QgsCoordinateReferenceSystem I have not found a method able to do that check.
>> Thanks for your attention
>> Pierluigi
>> Ing. Pierluigi De Rosa (PhD in Earth Science)
>> Contract Professor of Geographic Information System at University of Perugia
>> cel: 3497558268 / fax: 075 7823038
>> skype: pierluigi.derosa
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Mit freundlichen Grüßen
>> Stefan Giese
>> Projektleiter/Consultant
>> Schon gewusst?
>> In unserem Blog geben wir Tipps & Tricks zu
>> Open-Source-GIS-Software und berichten aus unserem Experten-Alltag:
>> https://wheregroup.com/blog/
>> WhereGroup GmbH
>> Schwimmbadstr. 2
>> 79100 Freiburg
>> Germany
>> Fon: +49 (0)761 / 519 102 - 61
>> Fax: +49 (0)761 / 519 102 - 11
>> www.wheregroup.com
>> Geschäftsführer:
>> Olaf Knopp, Peter Stamm
>> Amtsgericht Bonn, HRB 9885
Stefan Giese
Aufwind durch Wissen!
Jetzt neu: Webinare und Online-Schulungen
bei der www.foss-academy.com
WhereGroup GmbH
Schwimmbadstr. 2
79100 Freiburg
Germany
www.wheregroup.com
Geschäftsführer:
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20211014/51557f3c/attachment.sig>
More information about the QGIS-Developer mailing list
