[QGIS-Developer] Crash in QgsAppication.initQgis()
Asim asimrp at lavabit.com
Mon Oct 18 18:26:19 PDT 2021
On 8/20/21 6:38 PM, Asim wrote:
> The stack trace indicates QgsProject failed to get created because
> sqlite3_create_function_v2() tried to de-reference a NULL pointer.
> Full stack trace is attached.  Is this something MacOS specific?
Apparently, the libsqlite3 installed natively in MacOS is different from
libsqlite3 that is bundled within QGIS.  The workaround is to set
DYLD_INSERT_LIBRARIES environment variable to the libsqlite3.dylib
library within QGIS installation. More details can be found in
https://github.com/qgis/QGIS/issues/40378
Asim
More information about the QGIS-Developer mailing list
