[QGIS-Developer] Trouble compiling QGIS
Andreas Neumann a.neumann at carto.net
Fri Sep 3 07:49:48 PDT 2021
Hi Even,
With "valgrind output/bin/crssync" I can see that two different
"libproj"-versions are involved with crssync:
/usr/lib/x86_64-linux-gnu/libproj.so.15.3.1
and
/usr/local/lib/libproj.so.22.1.0
I guess I will have to find out which library is still referencing the
old libproj version - perhaps that libspatialite culprit again ...
Thanks for your hints,
Andreas
On 2021-09-03 15:42, Even Rouault wrote:
> Andreas
> Several things to check:
> - Is your GDAL build a clean one ? That is is it from a fresh build
> directory, or are you rebuilding in a directory where a previous build
> was done. If the later, make sure to "make clean" before rebuilding
> - Is your GDAL build using your custom GEOS one ? Otherwise QGIS might
> link directly to the custom one and indirectly to the system one
> through GDAL. Check the output of "ldd output/bin/qgis | grep geos"
> - try "valgrind output/bin/crssync". Emitted stack traces can give
> interesting hints
> Even
> Le 03/09/2021 à 15:30, Andreas Neumann a écrit :
>> Hi,
>> I have troubles compiling QGIS on my Linux Ubuntu 20.04 machine.
>> I use a self-compiled GEOS and GDAL.
>> The build always hangs at "crssync" - here is the ninja build output I
>> get. Do you have any idea what might be wrong or what I could do in
>> order to fix this problem?
>> Thank you for your hints,
>> Andreas
>> [0/1] Re-running CMake...
>> -- QGIS version: 3.21.0 Master (32100)
>> -- Found OpenCL C++ headers: /usr/include
>> -- ccache found
>> -- Found Proj: /usr/local/lib/libproj.so version 8 (8.1.0)
>> -- Found GEOS: /usr/local/lib/libgeos_c.so (3.9.1)
>> -- Found GDAL: /usr/local/lib/libgdal.so (3.3.1)
>> -- Found Expat: /usr/lib/x86_64-linux-gnu/libexpat.so
>> -- Found Spatialindex: /usr/lib/x86_64-linux-gnu/libspatialindex.so
>> -- Found Qwt: /usr/lib/libqwt-qt5.so (6.1.4)
>> -- Found libzip: /usr/lib/x86_64-linux-gnu/libzip.so
>> -- Found Sqlite3: /usr/lib/x86_64-linux-gnu/libsqlite3.so
>> -- Found Protobuf: /usr/lib/x86_64-linux-gnu/libprotobuf.so;-pthread
>> -- Found zlib: /usr/lib/x86_64-linux-gnu/libz.so
>> -- Found exiv2: /usr/lib/x86_64-linux-gnu/libexiv2.so
>> -- Found PostgreSQL: /usr/local/pgsql/lib/libpq.so
>> -- Found SpatiaLite: /usr/local/lib/libspatialite.so
>> -- Qt WebKit support enabled
>> -- Found ZSTD: /usr/lib/x86_64-linux-gnu/libzstd.so
>> -- Found laz-perf: /usr/local/include
>> -- Found PDAL:
>> /usr/local/lib/libpdalcpp.so;/usr/local/lib/libpdal_util.so (2.0.1)
>> -- Found Qt version: 5.12.8
>> -- Found QScintilla2: /usr/lib/libqscintilla2_qt5.so (2.11.2)
>> -- Found QtKeychain: /usr/lib/x86_64-linux-gnu/libqt5keychain.so
>> -- Found QCA: /usr/lib/x86_64-linux-gnu/libqca-qt5.so (2.2.1)
>> -- Found QCA OpenSSL plugin
>> -- Pedantic compiler settings enabled
>> -- Found GSL: -L/usr/lib/x86_64-linux-gnu -lgsl -lgslcblas -lm
>> -- Found Python executable: /usr/bin/python3.8 (version 3.8.10)
>> -- Python library: /usr/lib/x86_64-linux-gnu/libpython3.8.so
>> -- Python site-packages: /usr/lib/python3/dist-packages
>> -- Found PyQt5 version: 5.14.1
>> -- Found SIP version: 4.19.21
>> -- Found QScintilla2 PyQt module: 2.11.2
>> -- Could NOT find HDF5 (missing: HDF5_LIBRARIES HDF5_INCLUDE_DIRS)
>> (found version "")
>> -- Could NOT find NetCDF (missing: NETCDF_LIBRARY NETCDF_INCLUDE_DIR)
>> -- Using PROJ >= 6 srs database.
>> -- Ctest Binary Directory set to:
>> /home/bjsvwneu/dev/QGIS/build/output/bin
>> -- Configuring done
>> -- Generating done
>> -- Build files have been written to: /home/bjsvwneu/dev/QGIS/build
>> [1/6072] Generating qgsversion.h, qgsversion.inc
>> Files "/home/bjsvwneu/dev/QGIS/build/qgsversion.h.temp" to
>> "/home/bjsvwneu/dev/QGIS/build/qgsversion.h" are different.
>> [3/6072] Generating qgsexpression_texts.cpp
>> Files
>> "/home/bjsvwneu/dev/QGIS/build/src/core/qgsexpression_texts.cpp.temp"
>> to "/home/bjsvwneu/dev/QGIS/build/src/core/qgsexpression_texts.cpp"
>> are different.
>> [2905/6072] Generating gui/sip_guipart0.cpp, gui/sip_guipart1.cpp,
>> gui/sip_guipart2.cpp, gui/sip_guipart3.cpp, gui/sip_guipart4.cpp,
>> g...i/sip_guipart10.cpp, gui/sip_guipart11.cpp, gui/sip_guipart12.cpp,
>> gui/sip_guipart13.cpp, gui/sip_guipart14.cpp, gui/sip_guipart15.cpp
>> [4061/6072] Building CXX object
>> src/providers/mdal/CMakeFiles/provider_mdal.dir/__/__/__/external/mdal/mdal_utils.cpp.o
>> ../external/mdal/mdal_utils.cpp: In function 'int
>> MDAL::toInt(size_t)':
>> ../external/mdal/mdal_utils.cpp:143:14: warning: comparison of integer
>> expressions of different signedness: 'const size_t' {aka 'const long
>> unsigned int'} and 'int' [-Wsign-compare]
>> 143 |   if ( value > std::numeric_limits<int>::max() )
>> [4172/6072] Running crssync
>> FAILED: src/crssync/CMakeFiles/synccrsdb
>> cd /home/bjsvwneu/dev/QGIS/build/src/crssync &&
>> /home/bjsvwneu/dev/QGIS/build/output/bin/crssync
>> free(): invalid pointer
>> Aborted (core dumped)
>> [4173/6072] Building CXX object
>> src/plugins/topology/CMakeFiles/topolplugin.dir/topolplugin_autogen/mocs_compilation.cpp.o
>> ninja: build stopped: subcommand failed.
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210903/05e7792f/attachment-0001.html>
More information about the QGIS-Developer mailing list
