[QGIS-Developer] Plugin dependency with binaries: 'best' way to guide user to install?
Aron Gergely aron.gergely at rasterra.nl
Tue Apr 5 10:28:09 PDT 2022
Thank you, I checked out your plugin - yes that seems also a good way.
I already had the logic to detect, throw message, guide to dialog,
etc... implemented similar to yours.
But I wanted to let pip manage the actual package, so I went with the
subprocess+pip route. Here is a minimum working example:
import subprocess
import sys
try:
     subprocess.check_call((sys.executable, '-m', 'pip', 'install', 'h3<=3.99'))
except subprocess.CalledProcessErroras e:
     raise e# handle any errors here instead
I connected it to a button in a dialog. And catch stdout, stderr and the
exit code of the subprocess so I can show the user what is happening.
Have not yet tried on other platforms than Linux. But sys.executable is
there to solve the ambiguity of python executable path.
Best regards,
Aron
On 01-04-2022 14:07, Pedro Camargo via QGIS-Developer wrote:
> Take a look at how it is done in the AequilibraE plugin.
> I basically ship the plugin without the binaries and create a menu
> item where the user can choose to download the binaries.
> Once downloaded, restarting the plugin allows it to identify the
> binaries and deactivate that menu item.
> Cheers,
> Pedro
> ---- On Fri, 01 Apr 2022 05:00:02 +1000
> *qgis-developer-request at lists.osgeo.org * wrote ----
>     Send QGIS-Developer mailing list submissions to
>     qgis-developer at lists.osgeo.org
>     To subscribe or unsubscribe via the World Wide Web, visit
>     https://lists.osgeo.org/mailman/listinfo/qgis-developer
>     or, via email, send a message with subject or body 'help' to
>     You can reach the person managing the list at
>     qgis-developer-owner at lists.osgeo.org
>     When replying, please edit your Subject line so it is more specific
>     than "Re: Contents of QGIS-Developer digest..."
>     Today's Topics:
>     1. Plugin dependency with binaries: 'best' way to guide user to
>     install? (Aron Gergely)
>     2. Unexpected results from GPKG table query using executeSql()
>     (Raymond Nijssen)
>     3. Re: Unexpected results from GPKG table query using
>     executeSql() (Alessandro Pasotti)
>     4. Re: Unexpected results from GPKG table query using
>     executeSql() (Raymond Nijssen)
>     Message: 1
>     Date: Thu, 31 Mar 2022 14:09:21 +0200
>     From: Aron Gergely <aron.gergely at rasterra.nl>
>     To: qgis-dev <qgis-developer at lists.osgeo.org>
>     Subject: [QGIS-Developer] Plugin dependency with binaries: 'best' way
>     Message-ID: <5e3173ec-7b7e-64da-47d1-79d39edc1c10 at rasterra.nl>
>     Content-Type: text/plain; charset=UTF-8; format=flowed
>     Hi All,
>     What would be a good practice to handle 3rd party libs which can't be
>     shipped together with a plugin?
>     I am looking for the most user-friendly way and have an idea.
>     But thought I would bounce it off the collective wisdom here and
>     see if
>     there are other/better ways.
>     If we find a 'best' method I could PR an update to the QGIS docs or
>     PyQGIS cookbook, etc to preserve that knowledge.
>     Bit of context:
>     I have a plugin that uses a 3rd party python library which has
>     binaries.
>     I would like to submit this plugin to the official plugin repository.
>     According to https://plugins.qgis.org/publish/ it's not allowed to
>     ship
>     binaries it with the plugin.
>     In such case the above webpage recommends telling the end user to run
>     "pip.main(...)" from the python console to install missing libraries.
>     I thought that's not user friendly and it's a pip hack (pip.main() is
>     meant to be internal).
>     Also, I want to handle the missing python module in my plugin
>     gracefully: check on plugin load if missing, if so, guide user to
>     resolve, preferably without having them write or copy any commands.
>     The idea:
>     Using python's subprocess module from within the plugin to call
>     the pip
>     CLI, which would install the package the usual pip way. Here's why:
>     - pip project recommends this way as best practice, warns against the
>     pip.main()
>     - user would not need to write or copy-paste commands
>     - could make this user friendly: wire it in the plugin code to a push
>     button and build it into a dialog e.g.;? if lib is missing on
>     plugin load,
>     ? show a QMessageBox and let user open a dialog to resolve. In that
>     dialog would be the push button to trigger the pip install via
>     subprocess.
>     How would this play out multi-platform via subprocess, I have no
>     idea of
>     yet - thought if the idea survived this thread, I'd go find out ;)
>     Do you think this subprocess + pip is a good idea?
>     Would it be allowed for plugins in the official repository to
>     behave as
>     such?
>     Anyone has other user-friendly ways of doing this?
>     Best regards,
>     Aron
>     Message: 2
>     Date: Thu, 31 Mar 2022 18:09:25 +0200
>     From: Raymond Nijssen <r.nijssen at terglobo.nl>
>     To: qgis-developer <qgis-developer at lists.osgeo.org>
>     Subject: [QGIS-Developer] Unexpected results from GPKG table query
>         using executeSql()
>     Message-ID: <bba11f52-a64a-6502-fbce-dbc986ba9391 at terglobo.nl>
>     Hi devs,
>     I'm working on a plugin that connects to a custom table (without
>     geometry) in a GPKG. When I'm sending queries to it, I keep on
>     getting
>     unexpected results. Somehow the id field is missing, sometimes it
>     appears twice (!). And this seems to be different between QGIS
>     3.10 and
>     3.25. (I think it changed since 3.22).
>     Here is a piece of my code:
>     fn = '/path/to/test.gpkg'
>     md = QgsProviderRegistry.instance().providerMetadata('ogr')
>     conn = md.createConnection(fn, {})
>     q = 'select * from test_table;'
>     qr = conn.executeSql(q)
>     print(qr) # No id field in result
>     Before diving into the QGIS code I'd like to check if this is the
>     way to
>     go. Or should i use another way to query that GPKG (SQLite) db?
>     Kind regards,
>     Raymond
>     Message: 3
>     Date: Thu, 31 Mar 2022 18:15:00 +0200
>     From: Alessandro Pasotti <apasotti at gmail.com>
>     To: Raymond Nijssen <r.nijssen at terglobo.nl>
>     Cc: qgis-developer <qgis-developer at lists.osgeo.org>
>     Subject: Re: [QGIS-Developer] Unexpected results from GPKG table
>     query
>         using executeSql()
>     Message-ID:
>         <CAL5Q670rrD--ZvEVDTtCWEqU1vZgUe7Nh+e58MLMDMQNPF9h1w at mail.gmail.com>
>     Content-Type: text/plain; charset="utf-8"
>     Hi Raymond,
>     your code looks good.
>     Can you provide a test file?
>     There are some test in core here:
>     https://github.com/qgis/QGIS/blob/master/tests/src/python/test_qgsproviderconnection_ogr_gpkg.py
>     On Thu, Mar 31, 2022 at 6:09 PM Raymond Nijssen via QGIS-Developer <
>     qgis-developer at lists.osgeo.org> wrote:
>     > Hi devs,
>     getting
>     3.10 and
>     the way to
>     > Kind regards,
>     > Raymond
>     > _______________________________________________
>     > QGIS-Developer at lists.osgeo.org
>     > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>     > Unsubscribe:
>     Alessandro Pasotti
>     QCooperative: www.qcooperative.net
>     ItOpen: www.itopen.it
>     -------------- next part --------------
>     An HTML attachment was scrubbed...
>     URL:
>     <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20220331/ad1ec7b7/attachment-0001.html>
>     Message: 4
>     Date: Thu, 31 Mar 2022 18:52:48 +0200
>     To: Alessandro Pasotti <apasotti at gmail.com>
>     query
>         using executeSql()
>     Message-ID: <87330c53-a8a5-6e07-dd6e-006fcdd7710f at terglobo.nl>
>     Hi Alessandro,
>     Thanks for your reply. Will share data and a test script with you
>     privately.
>     Raymond
>     On 31-03-2022 18:15, Alessandro Pasotti wrote:
>     > Hi Raymond,
>     <https://github.com/qgis/QGIS/blob/master/tests/src/python/test_qgsproviderconnection_ogr_gpkg.py>
>     <mailto:qgis-developer at lists.osgeo.org>>
>     > wrote:
>     > Hi devs,
>     getting
>     3.10 and
>     > way to
>     > Kind regards,
>     > Raymond
>     <mailto:QGIS-Developer at lists.osgeo.org>
>     > <https://lists.osgeo.org/mailman/listinfo/qgis-developer>
>     > Unsubscribe:
>     > Alessandro Pasotti
>     > QCooperative: www.qcooperative.net <https://www.qcooperative.net>
>     > ItOpen: www.itopen.it <http://www.itopen.it>
>     Subject: Digest Footer
>     Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>     End of QGIS-Developer Digest, Vol 197, Issue 39
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-developer
Email Signature Kind Regards,
Aron Gergely
+31 (0) 6 38 70 97 66
*Rasterra* | www.rasterra.nl
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20220405/6654bc41/attachment-0001.html>
More information about the QGIS-Developer mailing list
