[QGIS-Developer] createAlgorithmDialog in Processing script (within plugin)
matteo matteo.ghetta at gmail.com
Mon Aug 1 06:23:12 PDT 2022
Hi all,
I've a set of custom processing scripts within a plugin (that is both
"normal" and processing provider plugin).
I'm trying to executing the dialog of these algorithm from one of the
main plugin file. I found the processing.createAlgorithmDialog [0], but
it is constantly crashing when I'm passing the instance of the algorithm:
my_alg = MyCustomAlg()
my_dialog = my_alg.createAlgorithmDialog(custom_dict)
## crash here
Thinking it was a problem of the threads I also tried to overwrite the
`flag` method in the algorithm by setting also
QgsProcessingAlgorithm.FlagNoThreading but with the same results.
I know I can run the processing algorithm with processing.run(....) but
I need to open the dialog pre-filled with custom parameters and to get
also some other outputs besides the standard ones (like the
QgsFeatureSink path)
Thanks for any suggestion
Cheers
Matteo
[0]
https://github.com/qgis/QGIS/blob/master/python/plugins/processing/tools/general.py#L155
More information about the QGIS-Developer mailing list
