[QGIS-Developer] Unable to build master on Ubuntu 22.04
Jorge Gustavo Rocha
jgr at di.uminho.pt
Wed Aug 24 04:19:43 PDT 2022
Hi Harrissou,
Recently our PDAL friends introduced in CMakeLists.txt:
set(CMAKE_CXX_STANDARD 17)
set(CMAKE_CXX_STANDARD_REQUIRED ON)
For those compiling PDAL + GDAL + QGIS, maybe we need to use gcc-11. Is
this you case?
Building QGIS and all required software works on my 22.04 (with gcc-11).
Best regards,
Jorge
On 24/08/22 11:33, Delaz J via QGIS-Developer wrote:
> Hi devs,
> I had a working build of QGIS master on ubuntu 22.04. Everything
> worked nicely but because it was minimum 2/3 weeks old, I pulled
> changes from upstream and tried to rebuild. Fail! I then deleted my
> build folder and redo a ccmake -G Ninja .., configured (no big changes
> other than Debug cmake_build_type, with_3D on and no GRASS) and
> launched the build. Still nothing. It just fails and I see no
> information why. Any idea how to fix or how I can output error reasons
> would be really appreciated.
> Below all that I get.
> Thanks and kind regards,
> Harrissou
> > ninja -j4 && ./output/bin/qgis
> [9/1820] Building CXX object src/app/CMakeFiles/qgis_app.dir/qgisapp.cpp.o
> FAILED: src/app/CMakeFiles/qgis_app.dir/qgisapp.cpp.o
> ccache /usr/bin/c++ -DQT_3DCORE_LIB -DQT_3DEXTRAS_LIB -DQT_3DINPUT_LIB
> -DQT_3DLOGIC_LIB -DQT_3DRENDER_LIB -DQT_CONCURRENT_LIB -DQT_CORE_LIB
> -DQT_DBUS_LIB -DQT_DEPRECATED_WARNINGS
> -DQT_DISABLE_DEPRECATED_BEFORE=0x050800 -DQT_GUI_LIB -DQT_NETWORK_LIB
> -DQT_NO_CAST_TO_ASCII -DQT_NO_FOREACH -DQT_POSITIONING_LIB
> -DQT_PRINTSUPPORT_LIB -DQT_QMLMODELS_LIB -DQT_QML_LIB
> -DQT_QUICKWIDGETS_LIB -DQT_QUICK_LIB -DQT_SERIALPORT_LIB -DQT_SQL_LIB
> -DQT_SVG_LIB -DQT_UITOOLS_LIB -DQT_USE_QSTRINGBUILDER
> -DQT_WEBKITWIDGETS_LIB -DQT_WEBKIT_LIB -DQT_WIDGETS_LIB -DQT_XML_LIB
> -DSIP_VERSION=0x060501
> -DTEST_DATA_DIR=\"/media/delazj/github/QGIS/tests/testdata\"
> -DWITH_BINDINGS -DWITH_QTWEBKIT -Dqgis_app_EXPORTS
> -I/media/delazj/github/QGIS/build-ninja/src/app/qgis_app_autogen/include
> -I/media/delazj/github/QGIS/external/nmea
> -I/media/delazj/github/QGIS/src/app
> -I/media/delazj/github/QGIS/src/app/decorations
> -I/media/delazj/github/QGIS/src/app/devtools/networklogger
> -I/media/delazj/github/QGIS/src/app/labeling
> -I/media/delazj/github/QGIS/src/app/layout
> -I/media/delazj/github/QGIS/src/app/pluginmanager
> -I/media/delazj/github/QGIS/src/app/gps
> -I/media/delazj/github/QGIS/src/app/dwg
> -I/media/delazj/github/QGIS/src/app/maptools
> -I/media/delazj/github/QGIS/src/app/mesh
> -I/media/delazj/github/QGIS/src/app/locator
> -I/media/delazj/github/QGIS/src/app/pointcloud
> -I/media/delazj/github/QGIS/src/app/vectortile
> -I/media/delazj/github/QGIS/src/plugins
> -I/media/delazj/github/QGIS/src/python
> -I/media/delazj/github/QGIS/src/native
> -I/media/delazj/github/QGIS/src/app/3d
> -I/media/delazj/github/QGIS/src/core
> -I/media/delazj/github/QGIS/build-ninja/src/core
> -I/media/delazj/github/QGIS/src/core/3d
> -I/media/delazj/github/QGIS/src/core/annotations
> -I/media/delazj/github/QGIS/src/core/auth
> -I/media/delazj/github/QGIS/src/core/browser
> -I/media/delazj/github/QGIS/src/core/callouts
> -I/media/delazj/github/QGIS/src/core/classification
> -I/media/delazj/github/QGIS/src/core/diagram
> -I/media/delazj/github/QGIS/src/core/dxf
> -I/media/delazj/github/QGIS/src/core/editform
> -I/media/delazj/github/QGIS/src/core/effects
> -I/media/delazj/github/QGIS/src/core/elevation
> -I/media/delazj/github/QGIS/src/core/expression
> -I/media/delazj/github/QGIS/src/core/externalstorage
> -I/media/delazj/github/QGIS/src/core/fieldformatter
> -I/media/delazj/github/QGIS/src/core/geometry
> -I/media/delazj/github/QGIS/src/core/geocms
> -I/media/delazj/github/QGIS/src/core/geocms/geonode
> -I/media/delazj/github/QGIS/src/core/geocoding
> -I/media/delazj/github/QGIS/src/core/gps
> -I/media/delazj/github/QGIS/src/core/labeling
> -I/media/delazj/github/QGIS/src/core/layertree
> -I/media/delazj/github/QGIS/src/core/layout
> -I/media/delazj/github/QGIS/src/core/locator
> -I/media/delazj/github/QGIS/src/core/maprenderer
> -I/media/delazj/github/QGIS/src/core/mesh
> -I/media/delazj/github/QGIS/src/core/metadata
> -I/media/delazj/github/QGIS/src/core/network
> -I/media/delazj/github/QGIS/src/core/numericformats
> -I/media/delazj/github/QGIS/src/core/pal
> -I/media/delazj/github/QGIS/src/core/plot
> -I/media/delazj/github/QGIS/src/core/pointcloud
> -I/media/delazj/github/QGIS/src/core/pointcloud/expression
> -I/media/delazj/github/QGIS/src/core/processing
> -I/media/delazj/github/QGIS/src/core/processing/models
> -I/media/delazj/github/QGIS/src/core/proj
> -I/media/delazj/github/QGIS/src/core/project
> -I/media/delazj/github/QGIS/src/core/providers
> -I/media/delazj/github/QGIS/src/core/providers/arcgis
> -I/media/delazj/github/QGIS/src/core/providers/memory
> -I/media/delazj/github/QGIS/src/core/providers/gdal
> -I/media/delazj/github/QGIS/src/core/providers/ogr
> -I/media/delazj/github/QGIS/src/core/providers/meshmemory
> -I/media/delazj/github/QGIS/src/core/raster
> -I/media/delazj/github/QGIS/src/core/renderer
> -I/media/delazj/github/QGIS/src/core/scalebar
> -I/media/delazj/github/QGIS/src/core/settings
> -I/media/delazj/github/QGIS/src/core/symbology
> -I/media/delazj/github/QGIS/src/core/textrenderer
> -I/media/delazj/github/QGIS/src/core/validity
> -I/media/delazj/github/QGIS/src/core/vector
> -I/media/delazj/github/QGIS/src/core/vectortile
> -I/media/delazj/github/QGIS/external/nlohmann
> -I/media/delazj/github/QGIS/external/kdbush/include
> -I/media/delazj/github/QGIS/external/rtree/include
> -I/media/delazj/github/QGIS/external/meshOptimizer
> -I/media/delazj/github/QGIS/src/core/providers/ept
> -I/media/delazj/github/QGIS/src/core/providers/copc
> -I/media/delazj/github/QGIS/src/gui
> -I/media/delazj/github/QGIS/src/gui/annotations
> -I/media/delazj/github/QGIS/src/gui/attributeformconfig
> -I/media/delazj/github/QGIS/src/gui/symbology
> -I/media/delazj/github/QGIS/src/gui/attributetable
> -I/media/delazj/github/QGIS/src/gui/auth
> -I/media/delazj/github/QGIS/src/gui/callouts
> -I/media/delazj/github/QGIS/src/gui/codeeditors
> -I/media/delazj/github/QGIS/src/gui/devtools
> -I/media/delazj/github/QGIS/src/gui/editorwidgets
> -I/media/delazj/github/QGIS/src/gui/editorwidgets/core
> -I/media/delazj/github/QGIS/src/gui/effects
> -I/media/delazj/github/QGIS/src/gui/elevation
> -I/media/delazj/github/QGIS/src/gui/history
> -I/media/delazj/github/QGIS/src/gui/labeling
> -I/media/delazj/github/QGIS/src/gui/layertree
> -I/media/delazj/github/QGIS/src/gui/layout
> -I/media/delazj/github/QGIS/src/gui/locator
> -I/media/delazj/github/QGIS/src/gui/maptools
> -I/media/delazj/github/QGIS/src/gui/mesh
> -I/media/delazj/github/QGIS/src/gui/numericformats
> -I/media/delazj/github/QGIS/src/gui/ogr
> -I/media/delazj/github/QGIS/src/gui/plot
> -I/media/delazj/github/QGIS/src/gui/processing
> -I/media/delazj/github/QGIS/src/gui/processing/models
> -I/media/delazj/github/QGIS/src/gui/providers
> -I/media/delazj/github/QGIS/src/gui/providers/gdal
> -I/media/delazj/github/QGIS/src/gui/providers/ogr
> -I/media/delazj/github/QGIS/src/gui/pointcloud
> -I/media/delazj/github/QGIS/src/gui/raster
> -I/media/delazj/github/QGIS/src/gui/settings
> -I/media/delazj/github/QGIS/src/gui/tableeditor
> -I/media/delazj/github/QGIS/src/gui/vector
> -I/media/delazj/github/QGIS/src/gui/vectortile
> -I/media/delazj/github/QGIS/build-ninja/src/gui
> -I/media/delazj/github/QGIS/build-ninja/src/ui
> -I/media/delazj/github/QGIS/src/gui/providers/ept
> -I/media/delazj/github/QGIS/src/gui/providers/copc
> -I/media/delazj/github/QGIS/build-ninja/src/native
> -I/media/delazj/github/QGIS/src/analysis
> -I/media/delazj/github/QGIS/src/analysis/georeferencing
> -I/media/delazj/github/QGIS/src/analysis/interpolation
> -I/media/delazj/github/QGIS/src/analysis/mesh
> -I/media/delazj/github/QGIS/src/analysis/network
> -I/media/delazj/github/QGIS/src/analysis/processing
> -I/media/delazj/github/QGIS/src/analysis/raster
> -I/media/delazj/github/QGIS/src/analysis/vector
> -I/media/delazj/github/QGIS/src/analysis/vector/geometry_checker
> -I/media/delazj/github/QGIS/build-ninja/src/analysis
> -I/media/delazj/github/QGIS/external/libdxfrw
> -I/media/delazj/github/QGIS/build-ninja/src/python
> -I/media/delazj/github/QGIS/src/3d
> -I/media/delazj/github/QGIS/src/3d/chunks
> -I/media/delazj/github/QGIS/src/3d/lights
> -I/media/delazj/github/QGIS/src/3d/materials
> -I/media/delazj/github/QGIS/src/3d/mesh
> -I/media/delazj/github/QGIS/src/3d/processing
> -I/media/delazj/github/QGIS/src/3d/shaders
> -I/media/delazj/github/QGIS/src/3d/symbols
> -I/media/delazj/github/QGIS/src/3d/terrain
> -I/media/delazj/github/QGIS/build-ninja/src/3d
> -I/media/delazj/github/QGIS/external/delaunator-cpp -isystem
> /usr/include/postgresql -isystem
> /media/delazj/github/QGIS/external/qt-unix-signals -isystem
> /usr/include/x86_64-linux-gnu/qt5 -isystem
> /usr/include/x86_64-linux-gnu/qt5/QtSql -isystem
> /usr/include/x86_64-linux-gnu/qt5/QtCore -isystem
> /usr/lib/x86_64-linux-gnu/qt5/mkspecs/linux-g++ -isystem
> /usr/include/x86_64-linux-gnu/qt5/QtUiTools -isystem
> /usr/include/x86_64-linux-gnu/qt5/QtWidgets -isystem
> /usr/include/x86_64-linux-gnu/qt5/QtGui -isystem
> /usr/include/x86_64-linux-gnu/qt5/QtWebKitWidgets -isystem
> /usr/include/x86_64-linux-gnu/qt5/QtWebKit -isystem
> /usr/include/x86_64-linux-gnu/qt5/QtNetwork -isystem
> /usr/include/x86_64-linux-gnu/qt5/QtXml -isystem
> /usr/include/x86_64-linux-gnu/qt5/QtSvg -isystem
> /usr/include/x86_64-linux-gnu/qt5/QtPrintSupport -isystem
> /usr/include/x86_64-linux-gnu/qt5/QtConcurrent -isystem
> /usr/include/gdal -isystem /usr/include/Qca-qt5/QtCrypto -isystem
> /usr/include/qt5keychain -isystem
> /usr/include/x86_64-linux-gnu/qt5/QtSerialPort -isystem
> /usr/include/x86_64-linux-gnu/qt5/QtPositioning -isystem
> /usr/include/qwt -isystem /usr/include/x86_64-linux-gnu/qt5/QtDBus
> -isystem /usr/include/x86_64-linux-gnu/qt5/QtQuickWidgets -isystem
> /usr/include/x86_64-linux-gnu/qt5/QtQuick -isystem
> /usr/include/x86_64-linux-gnu/qt5/QtQmlModels -isystem
> /usr/include/x86_64-linux-gnu/qt5/QtQml -isystem
> /usr/include/x86_64-linux-gnu/qt5/Qt3DCore -isystem
> /usr/include/x86_64-linux-gnu/qt5/Qt3DRender -isystem
> /usr/include/x86_64-linux-gnu/qt5/Qt3DInput -isystem
> /usr/include/x86_64-linux-gnu/qt5/Qt3DLogic -isystem
> /usr/include/x86_64-linux-gnu/qt5/Qt3DExtras -Wall -Wextra
> -Wno-long-long -Wformat-security -Wno-strict-aliasing
> -Wnon-virtual-dtor -Wno-redundant-move -Wno-misleading-indentation
> -Wno-deprecated-copy -g -fPIC -fvisibility=hidden -fPIC -MD -MT
> src/app/CMakeFiles/qgis_app.dir/qgisapp.cpp.o -MF
> src/app/CMakeFiles/qgis_app.dir/qgisapp.cpp.o.d -o
> src/app/CMakeFiles/qgis_app.dir/qgisapp.cpp.o -c
> /media/delazj/github/QGIS/src/app/qgisapp.cpp
> c++: fatal error: Processus arrêté signal terminated program cc1plus
> compilation terminated.
> [12/1820] Building CXX object
> src/app/CMakeFiles/qgis_app.dir/qgsattributetabledialog.cpp.o
> ninja: build stopped: subcommand failed.
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
J. Gustavo
Jorge Gustavo Rocha
Departamento de Informática
Universidade do Minho
4710-057 Braga
Gabinete 3.29 (Piso 3)
Tel: +351 253604480
Fax: +351 253604471
Móvel: +351 910333888
skype: nabocudnosor
