[QGIS-Developer] Goal: High resolution GeoPDF importable to Avenza (Georeferencer plugin development question)
Shawn S sshawn09 at hotmail.com
Sun Jan 23 10:33:33 PST 2022
Greetings all,
I'm relatively new to QGIS and love it so far. My goal is to Georef a PDF map of a college campus for my legally blind brother and have it at a VERY HIGH resolution.
Method I'm using: Georeferencer plugin / Export map to Geo PDF
Problems:
  1.  Skewing of the map
  2.  Losing definition / resolution
  3.  Can be done easier?
Details:
  1.  When I mark the points of reference for my map, then open in QGIS, it is at a tilt. I am unable to rotate it and have it export pdf with the Geo option. It fails each time. If I don't rotate it, it will export fine.
  2.  Even when it does export in this manor, I lose resolution. First off, I can only export the view, not the borders of the original map, and then I lose space depending on my screen size / configuration.
  3.  The Georeferencer plugin is awesome, but lacks options. There is an option in that tool to export to pdf, when I do that I have AWESOME resolution and everything I need BUT.... It uses the coordinates from what looks like the Source X and Y, with approx. 0,0 at the top left of the map, and not the GPS coordinates. So if I open in Avenza, it puts me in the ocean near Afrika, not anywhere that my location should be. Is there a way to switch that or build in an option to do it correctly so I don't need to go into the QGIS export options at all? I can send pics if you'd like.
I'm open to trying other methods, and researching more as well so any help here is very very very much appreciated!
Thanks,
Shawn Schembri
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20220123/a8cf6285/attachment.html>
More information about the QGIS-Developer mailing list
