[QGIS-Developer] Vector Tiles in QGIS: throws "Error loading style: Style not found in database" with 'optional style url'
Patrick Dunford enzedrailmaps at gmail.com
Mon Jul 18 14:00:57 PDT 2022
Hi Richard
You could test it with the Linz Basemaps vector tile server
http://basemaps.linz.govt.nz
On 18/07/22 22:27, Richard Duivenvoorde via QGIS-Developer wrote:
> Ok, just found out: the layer is not loading IF there is NO other
> (xyz?) layer.
> So when it is the first layer you load, it will give the warning and
> NOT show anything.
> If you already loaded some other layer (for example OSM xyz), THEN all
> is fine
> I'll create an issue for it... wondering if there is some simple
> global vector tile server which has the same issue, so it is easier to
> reproduce...
> Regards,
> On 7/18/22 10:07, Richard Duivenvoorde via QGIS-Developer wrote:
>> Hi People,
>> Just playing with pg_tileserv, to check if QGIS was able to load
>> tiles from it with a small data set, I fail to load because:
>> "Error loading style: Style not found in database".
>> Though in the connection dialog it says that the Style URL is
>> Optional...
>> Am I missing something? Tried with a fresh profile.
>> Or is there some generic url I should/could use?
>> (have to dive into these styling url's, to create one...)
>> Regards,
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
