[QGIS-Developer] HOWTO INSTALL QGS ON LINUX WITH PROVIDER TO ORACLE SPATIAL
Richard Duivenvoorde rdmailings at duif.net
Mon Jun 20 22:42:28 PDT 2022
WHY ARE YOU SCREAMING THIS :-)
It is some time ago, but I did a write up of the process for CentOS some time ago:
https://zuidt.nl/blog/html/2015/10/12/build_qgis_master_with_oracle_provider_yourself_on_centos7.html
You need to adapt it for Ubuntu but it contains (I think) enough pointers if you are already familiar with compiling QGIS for Ubuntu..
HOPE THIS HELPS ;-)
Regards,
PS: why 20? should you not aim for 22? as that is the latest LTR?
On 6/21/22 06:39, Fredy Varon via QGIS-Developer wrote:
> Hi,
> I need help if someone knows howto install Qgis on Linux Ubuntu 20 to suport conection to Oracle to add layers from Oracle spatial
> Thanks
> */FREDY VARON GARCIA/*
> *Ing. Sistemas *
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
