[QGIS-Developer] action get measure
Andreas Neumann a.neumann at carto.net
Thu Jun 23 06:50:20 PDT 2022
Hi Silvain,
Hm - this will require a "Python action".
Because with a generic action you could do something like:
length(make_line($geometry,make_point(@click_x, at click_y)))
using a QGIS expression, but there are two problems:
- you can only get @click_x and @click_y if you click on the feature;
but since it is a point feature you cannot click outside the tolerance
of this point in order to receive the coordinates
- generic actions do not allow updates of data
So you'd have to use a Python action. If you Google for QGIS Python
actions, you should get some ideas how it works.
Andreas
On 2022-06-23 15:32, PIERRE Sylvain wrote:
> Hi Andreas,
> I want an interactive solution . Close to measurement tool except I can
> catch the length and update a field in the layer table.
> De : Andreas Neumann <a.neumann at carto.net>
> Envoyé : jeudi 23 juin 2022 15:29
> À : PIERRE Sylvain <sylvain.pierre at alsace.eu>
> Cc : qgis-developer at lists.osgeo.org
> Objet : Re: [QGIS-Developer] action get measure
> Soyez vigilant : ce courriel provient d'une organisation externe à la
> CeA.
> * Assurez-vous d'abord qu'il ne s'agit pas d'un email malveillant avant
> de cliquer sur tout lien ou pièce jointe.
> Apprendre à reconnaître un email de phishing. [6]
> Hi Sylvain,
> Do you want an interactive solution where the user should interactively
> draw a second point - or is the second point already in your data
> table?
> Andreas
> On 2022-06-23 14:42, PIERRE Sylvain via QGIS-Developer wrote:
>> Hi ,
>> I want to build an action on a point layer, wich draw a line from a
>> point and store the lenght inside a field layer.
>> Is ther any way to do that ?
>> Thanks
>> Sylvain
>> Sylvain PIERRE
>> Chef de projet système d'information
>> Direction des Systèmes d'Information et du Développement Numérique
>> Service Projets et Ingénierie Numérique
>> Collectivité européenne d'Alsace
>> Tél : 03 88 76 68 88
>> www.alsace.eu [1]
>> [2]  [3]  [4]
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer [5]
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> [5]
Links:
[1] http://www.alsace.eu
[2] http://www.facebook.com/toutelalsace
[3] http://www.twitter.com/toutelalsace
[4] http://www.instagram.com/toutelalsace
[5] https://lists.osgeo.org/mailman/listinfo/qgis-developer
[6]
https://intranet.alsace.eu/actualites/apprenez-a-reconnaitre-un-email-phishing/
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20220623/0cd2f89b/attachment-0001.htm>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20220623/0cd2f89b/attachment-0001.jpg>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20220623/0cd2f89b/attachment-0003.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20220623/0cd2f89b/attachment-0004.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20220623/0cd2f89b/attachment-0005.png>
More information about the QGIS-Developer mailing list
