[QGIS-Developer] Time for db manager to become an "opt-in" plugin?
SIGéal sigeal at sigeal.com
Thu Jun 23 07:21:31 PDT 2022
+1 for improving QGIS UI consistency !
I recently posted a feature request about "Update SQL Layer" dialog
which IMHO should be non modal : https://github.com/qgis/QGIS/issues/49091
Reading this discussion, I tested further browser functionnalities and
came to the conclusion that "Execute SQL" dialog should also be non modal.
And I also wonder why these dialogs could not be included in the Browser
non modal window, similarly to what is done in DB Manager.
Just my two cents...
Christophe Damour
Le 22/06/2022 à 02:43, Nyall Dawson via QGIS-Developer a écrit :
> Hi list,
> I wanted to raise the discussion around potentially demoting the DB
> Manager plugin to become an opt-in, not installed by default plugin
> available from the QGIS plugin repository only.
> It's likely no surprise to anyone on this list, but there's been a
> multi-year effort (mostly thanks to Alessandro!) to move all the
> important functionality of db manager over to the QGIS browser. This
> was driven by a number of factors:
> - It was confusing and messy to expose database management tools
> through two completely separate parts of the QGIS interface
> - The DB Manager tools are written in provider-specific ways, and
> don't use generic QGIS database/provider API calls. As a result
> there's a lot of duplicate code there, and db manager doesn't gain the
> benefits of new data provider features. (E.g. only a subset of the
> databases supported by QGIS and the browser management tools are
> available for management in db manager)
> - The DB Manager functionality wasn't available for other parts of
> QGIS/plugins/scripts/etc to reuse, whereas the browser functionality
> is all nicely exposed to PyQGIS and is used by other parts of QGIS,
> eg. processing tools.
> - The Python code implementing db manager is fragile, and is subject
> to semi-frequent regressions/breakage (through no fault of the authors
> -- it's just the nature of complex python applications which aren't
> soaked in unit tests)
> I'd say we've reached a stage where the browser now offers all the
> common functionality also available in db manager, and we can start to
> seriously discuss the future of the plugin.
> My personal view is that we should demote the plugin to a
> community-maintained, non-officially supported plugin available only
> through the QGIS plugin repositories, and remove it from the default
> QGIS install.
> Thoughts/discussion welcome :)
> Nyall
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
