[QGIS-Developer] gdal2xyz.bat not accepting -b any band number
Alexandre Neto senhor.neto at gmail.com
Thu Jun 23 18:21:30 PDT 2022
Done
https://github.com/OSGeo/gdal/issues/5984
A sexta, 24/06/2022, 01:40, Even Rouault <even.rouault at spatialys.com>
escreveu:
> Le 24/06/2022 à 02:29, Alexandre Neto via QGIS-Developer a écrit :
> > I am testing the GDAL tools on QGIS 3.22.8 on Windows. When running
> > gdal2xyz with a single band raster I am getting the following error:
> > C:\Users\testing_user>gdal2xyz.bat -b 1
> > C:/Users/testing_user/Desktop/gdal_commands_test/mdt_clipped.tif
> > OUTPUT.csv
> > usage: gdal2xyz.py [-h] [-skip] [-srcwin xoff yoff xsize ysize] [-b
> > band [band ...]] [-allbands] [-csv] [-skipnodata]
> >                    [-srcnodata [SRC_NODATA ...]] [-dstnodata
> > [DST_NODATA ...]]
> >                    src_dataset dst_dataset
> > gdal2xyz.py: error: argument -b/-band/--band: invalid int value:
> > 'C:/Users/testing_user/Desktop/gdal_commands_test/mdt_clipped.tif'
> > If I remove the -b option it works.
> > Windows Is now on GDAL 3.5.0. On my linux machine that still uses GDAL
> > 3.0.4 it works fine.
> > Bug report? In here or in GDAL?
> to GDAL. It looks like the -b option is a bit too greedy in consuming
> arguments. A workaround is to put the -b 1 option at the end of the
> command line.
> > Alexandre Neto
> > QGIS-Developer mailing list
> > QGIS-Developer at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20220624/de659062/attachment.htm>
More information about the QGIS-Developer mailing list
