[QGIS-Developer] Compile Master with Debian Bullseye
Johannes Kröger (WhereGroup) johannes.kroeger at wheregroup.com
Mon Jun 27 08:02:39 PDT 2022
Hey Piet,
are your dependencies all installed and up to date? If you tried to
build before, try a `make clean` before trying again after updating. I
don't know much about this, but maybe it points you towards a solution.
Cheers, Hannes
Am 27.06.22 um 10:25 schrieb Piet via QGIS-Developer:
> Dear List,
> I like to compile Qgis Master with Debian Bullseye following the
> building guide https://github.com/qgis/QGIS/blob/master/INSTALL.md
> for Debian.
> "make" failed with this error:
> make[2]: *** [src/core/CMakeFiles/qgis_core.dir/build.make:15201:
> output/lib/libqgis_core.so.3.27.0] Fehler 1
> make[1]: *** [CMakeFiles/Makefile2:4208:
> src/core/CMakeFiles/qgis_core.dir/all] Fehler 2
> make: *** [Makefile:166: all] Fehler 2
> and logs a lot of similar messages like:
> /usr/bin/ld:
> CMakeFiles/qgis_core.dir/raster/qgsrasterfilewriter.cpp.o: in function
> `QgsRasterFileWriter::extensionsForFormat(QString const&)':
> qgsrasterfilewriter.cpp:(.text+0x7614): undefined reference to
> `GDALGetDriverByName'
> /usr/bin/ld: qgsrasterfilewriter.cpp:(.text+0x7640): undefined
> reference to `GDALGetMetadata'
> /usr/bin/ld: qgsrasterfilewriter.cpp:(.text+0x765f): undefined
> reference to `CSLFetchBoolean'
> /usr/bin/ld: qgsrasterfilewriter.cpp:(.text+0x7683): undefined
> reference to `GDALGetMetadataItem'
> Could you give me a tipp?
> Thank you!
> Kind regards
> Piet
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Johannes Kröger / GIS-Entwickler/-Berater
Schon gewusst?
In unserem Blog geben wir Tipps & Tricks zu Open-Source-GIS-Software
und berichten aus unserem Experten-Alltag:
https://wheregroup.com/blog/
WhereGroup GmbH
Grevenweg 89
20537 Hamburg
Germany
Tel: +49 (0)228 / 90 90 38 - 36
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
Type: application/pgp-keys
Desc: OpenPGP public key
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20220627/e8acecd7/attachment.key>
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20220627/e8acecd7/attachment.sig>
More information about the QGIS-Developer mailing list
