[QGIS-Developer] Problems building QGIS 3.26 using Python 3.10.5 and SIP 6.6.2
Hernán De Angelis variablestarlight at gmail.com
Tue Jun 28 08:50:12 PDT 2022
Hi developers,
I am trying to understand some errors I get while building either QGIS
3.26 or the latest main branch from GitHub in openSUSE Tumbleweed. I
normally compile the latest source every few weeks and normally things
go fine. Last few times I compiled Python was 3.8 and 3.9 and there were
no problems. However, recently this distribution I use has made Python3
= 3.10.5. SIP is 6.6.2. To my knowledge all other dependencies are
satisfied. I wonder if the change in Python or SIP versions may have
introduced some known incompatibility. Errors are listed below. Any hint
is appreciated.
Thanks in advance
/H.
sip-build: An internal error occurred...
   File "/bin/sip-build", line 33, in <module>
     sys.exit(load_entry_point('sip==6.6.2', 'console_scripts',
'sip-build')())
   File "/usr/lib64/python3.10/site-packages/sipbuild/tools/build.py",
line 37, in main
     handle_exception(e)
   File "/usr/lib64/python3.10/site-packages/sipbuild/exceptions.py",
line 81, in handle_exception
     raise e
line 34, in main
     project.build()
   File "/usr/lib64/python3.10/site-packages/sipbuild/project.py", line
244, in build
     self.builder.build()
   File "/usr/lib64/python3.10/site-packages/sipbuild/builder.py", line
48, in build
     self._generate_bindings()
277, in _generate_bindings
     buildable = bindings.generate()
   File "/usr/lib64/python3.10/site-packages/sipbuild/bindings.py", line
166, in generate
     spec, sip_files = parse(self.sip_file, SIP_VERSION, encoding,
   File
"/usr/lib64/python3.10/site-packages/sipbuild/generator/parser/parser.py",
line 35, in parse
     protected_is_public, include_dirs, strict).parse(sip_file)
   File
"/usr/lib64/python3.10/site-packages/sipbuild/generator/parser/parser_manager.py",
line 1507, in parse
     self._parser.parse(self._read(sip_file, raw_sip_file),
   File "/usr/lib/python3.10/site-packages/ply/yacc.py", line 331, in parse
     return self.parseopt(input, lexer, debug, tracking, tokenfunc)
   File "/usr/lib/python3.10/site-packages/ply/yacc.py", line 823, in
parseopt
     p.callable(pslice)
   File
"/usr/lib64/python3.10/site-packages/sipbuild/generator/parser/rules.py",
line 3029, in p_typedef_decl
     instantiated = pm.instantiate_class_template(p, name_symbol,
   File
line 1480, in instantiate_class_template
     instantiate_class(p, symbol, fq_cpp_name, tmpl_names, proto_class,
   File
"/usr/lib64/python3.10/site-packages/sipbuild/generator/parser/instantiations.py",
line 131, in instantiate_class
     i_class.ctors = _instantiate_ctors(tmpl_names, proto_class, template,
   File
line 235, in _instantiate_ctors
     i_ctor.py_signature = _instantiate_signature(proto_ctor.py_signature,
   File
line 368, in _instantiate_signature
     i_arg = _instantiate_argument(proto_arg, proto_class, tmpl_names,
   File
line 191, in _instantiate_argument
     i_arg.default_value = [_instantiate_value(v, expansions)
   File
line 191, in <listcomp>
   File
line 437, in _instantiate_value
     i_name = ScopedName.parse(template_string(proto_name, expansions))
   File
"/usr/lib64/python3.10/site-packages/sipbuild/generator/templates.py",
line 201, in template_string
     proto_str = proto_str.replace(name, value)
AttributeError: 'ScopedName' object has no attribute 'replace'
make[2]: ***
[python/CMakeFiles/python_module_qgis__analysis.dir/build.make:853:
python/analysis/build/_analysis/sip_analysispart0.cpp] Error 1
make[1]: *** [CMakeFiles/Makefile2:5790:
python/CMakeFiles/python_module_qgis__analysis.dir/all] Error 2
make[1]: *** Waiting for unfinished jobs....
'sip-build')())
line 37, in main
     handle_exception(e)
     raise e
line 34, in main
     project.build()
244, in build
48, in build
166, in generate
   File
line 35, in parse
   File
line 1507, in parse
parseopt
     p.callable(pslice)
   File
   File
   File
   File
   File
   File
   File
   File
   File
make[2]: ***
[python/CMakeFiles/python_module_qgis__core.dir/build.make:804:
python/core/build/_core/sip_corepart0.cpp] Error 1
make[1]: *** [CMakeFiles/Makefile2:5683:
python/CMakeFiles/python_module_qgis__core.dir/all] Error 2
'sip-build')())
line 37, in main
     handle_exception(e)
     raise e
line 34, in main
     project.build()
244, in build
48, in build
166, in generate
   File
line 35, in parse
   File
line 1507, in parse
parseopt
     p.callable(pslice)
   File
   File
   File
   File
   File
   File
   File
   File
   File
make[2]: ***
[python/CMakeFiles/python_module_qgis__gui.dir/build.make:1253:
python/gui/build/_gui/sip_guipart0.cpp] Error 1
make[1]: *** [CMakeFiles/Makefile2:5737:
python/CMakeFiles/python_module_qgis__gui.dir/all] Error 2
make: *** [Makefile:156: all] Error 2
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20220628/43e5e8ef/attachment-0001.htm>
More information about the QGIS-Developer mailing list
