[QGIS-Developer] Fwd: Compile Master with Debian Bullseye
Piet plist at posteo.eu
Wed Jun 29 04:24:00 PDT 2022
Dear Johannes,
thank you very much for your kind answer!
Meanwhile I solved this issue.
I don't know why, but ccmake does not find the gdal library and I added
the wrong library manually in the ccmake GUI.
After the change to the correct library the compilation works fine!
Kind regards
Piet
More information about the QGIS-Developer mailing list
